Oil & Fuel Case 480D
   / Case 480D #1
rshelley
Case 480D
Have a Case 480D Diesel Backhoe that will not start without help.
Let me start by saying that the engine had very old gas(2+yrs old) in it and it would not start. I hit it with a very light spray of starting fluid and it started right up. Ran without a problem but when cut off, it would not start back up. I read that you should never use starting fluid with diesels so I need to fix it so that I do not need to use starting fluid. I drained the old gas out and changed the fuel filters(both). Tried to crank it again with fresh diesel and no luck.
What's next? I have heard some engines get dependent on starting fluid so I cannot continue to use it as a solution(used maybe 5 times now).
Like I said, when cranked, it runs great with very little smoke. No other problems
2016 Chevrolet Impala Limited Sedan (A51694)
2016 Chevrolet...
NEW Wolverine 36'' Skid Steer Grapple Bucket (A53002)
NEW Wolverine 36''...
LMC LOT NUMBER 142 (A53084)
LMC LOT NUMBER 142...
2011 PETERBILT 337 (A52472)
2011 PETERBILT 337...
2013 Vermeer V800 T/A Towable Vacuum Trailer (A50324)
2013 Vermeer V800...
