Case 448 Removing engine to replace starter
   / Case 448 Removing engine to replace starter #1
rb3
kalamazoo, michigan
ingersoll 448
Hello, my name is Ray. Does anyone know if I have to loosen the allen bolt in the love joy coupling to remove the 448 engine? I am trying to check and or replace starter. I have hooker jumper cables directly to the starter and the gear comes forward and attempts to turn engine but can't start it. The bendix gear does not retract either and if I turn the key I can see starter try to turn engine and it just makes a clicking sound each time I turn the key. I was able to get the gear to retract with a thin wrench and the flywheel would turn with help of a big screwdriver. It seemed to turn pretty hard considering I removed both spark plugs. Do I need to remove fan and linkage to get to starter?
   / Case 448 Removing engine to replace starter #3
27ft x 24ft Metal Building (A51573)
27ft x 24ft Metal...
1994 Thomas Built SAF-T-LINER (LOW MILES, CUMMINS, ALLISON) (A52748)
1994 Thomas Built...
2019 MACK GR64F TANDEM AXLE CEMENT MIXER TRUCK (A52577)
2019 MACK GR64F...
2019 Bobcat T590 Compact Track Loader Skid Steer (A51691)
2019 Bobcat T590...
2019 INTERNATIONAL LT625 (A52472)
2019 INTERNATIONAL...
2012 Chevrolet Equinox 1LT SUV (A50324)
2012 Chevrolet...
