Case 430 wheels
   / Case 430 wheels #1
theonn
theodosia
case 430
I have a 430 case yesterday I blew a front tire and damaged the wheel beyond repair, I am wondering if there is a car wheel that will directly replace the front wheels.
   / Case 430 wheels #2
I have a 580B which has (IIRC) 10 lug front wheels, found a couple of pix of the 430 online and both the tractor version and the TLB version have six lug fronts. I don't know of a CAR with more than five.
You might find a truck or heavy trailer wheel that fits, but since those tractors had no front brakes, you may run into OTHER compatibility problems.
First thing you'll need is dimensions of your bolt pattern - since these are 6 lug, you just measure (probably on the GOOD wheel) center to center distance of two bolts OPPOSITE each other - this is your "circle" distance. so if you measure 5 inches, you would ask for a wheel with "6 on 5".
Beyond that, you'll need to know the width of the rim and its diameter.
If your tractor has a loader on it, I would NOT recommend a lower priced, lower load limit tire - you'll only end up back where you are now :confused:
Good luck... Steve
PORTER CABLE 150 PSI AIR COMPRESSOR (A50854)
PORTER CABLE 150...
2015 Volkswagen Passat 1.8T SE Sedan (A50324)
2015 Volkswagen...
2004 JOHN DEERE 5205 TRACTOR (A51406)
2004 JOHN DEERE...
2013 John Deere 4730 Self-Propelled Sprayer (A51039)
2013 John Deere...
2007 HYDRO-AX 764 MULCHING MACHINE (A51242)
2007 HYDRO-AX 764...
2003 FREIGHTLINER FL80 DUMP TRUCK (A51406)
2003 FREIGHTLINER...
