Loader Case 380CK hydraulic fluid
   / Case 380CK hydraulic fluid #1
dbcaseuser
case 380CK
Can anyone give me the transmission, hydraulic and powersteering fluid needed for a Case 380CK (75-76)
I ordered manuals for the tractor but it will be a while before I get them.
The transmission oil seems to be Case TCH fluid for which I got an equivalent locally.
The fluid in the transmission currently is greenish in color.
Also
Where does the power steering get it's fluid from on the 380, is the pump on the left hand side of the engine (with reservoir) running of a belt, the power steering pump or is it the hydraulic pump?
Since I just received the tractor I dont want to risk missing fluids that is low, before I get the manuals. As it seems there are only three oil reservoirs, namely Engine oil, Transmission oil, and the pump on the left side of the engine (contains bluish fluid) right?
Any help will be appreciated.
thanks.
Pallet Fees (A50775)
BESTWAY AG VSK35 LOT NUMBER 126 (A53084)
BESTWAY AG VSK35...
New/Unused 72in Quick Attach Mower King Hydraulic Brush Cutter (A51573)
New/Unused 72in...
2025 25ft. 800Amp Extra HD Booster Cables (A51692)
2025 25ft. 800Amp...
2004 MACK CX VISION (INOPERABLE) (A52472)
2004 MACK CX...
2008 D&P WELDING 18FT 2000 GAL FUEL TRAILER (A52472)
2008 D&P WELDING...
