Case 380B
   / Case 380B #1
Greyman441
Wasaga Beach, ON
IH 300 Utility, IH 434, Case 380B, MF 202 With backhoe, Farmall A
Good day all. I have a case 380B industrial tractor with loader. To the left of the steering wheel there is a forward/reverse selector. When the shift it to reverse and let the clutch out, the machine moves immediately, when I shift back to forward, there is a significant delay before the machine moves forward. Cold weather makes it worse, up to 5-6 seconds, warm weather 2 seconds. I simply shove the clutch back in and wait.....I don't like to leave the clutch out and simply wait until it moves as I don't want to burn the clutch out. The clutch once engaged is strong and will pull hard so it is not slipping. I was told that the reverse mech is spring loaded but forward is hydraulic. I have replaced the filter, hydraulic pump and all the fluid I could drain.
has anyone else had this issue with this tractor?? Looks a lot like a IH 485.
Thanks in advance.
2001 TRIPLE E INDUSTRIES 48X102 TRI-AXLE STEP DECK (A52472)
2001 TRIPLE E...
2018 XCMG XE210CU CRAWLER EXCAVATOR (A52576)
2018 XCMG XE210CU...
2014 ATC TRAILER (A52472)
2014 ATC TRAILER...
2007 Freightliner M2 106 Ambulance (A51692)
2007 Freightliner...
2005 Ford F-250 4x4 Reading Crane Service Truck (A51692)
2005 Ford F-250...
COOPER LIGHTING CAT. NO. MHEP-22/28-175-MT (A52748)
COOPER LIGHTING...
