case 350 crawler fuel pump
/ case 350 crawler fuel pump #1
wickemite
Windsor Nova Scotia,
Case 350
What do I need to know before I remove the fuel pump on my Case 350 dozer? Motor is a Case 188 Diesel
Any advice on how to loosen the retaining nut closest to engine block--------Wickemite
OK, well we figured things out and got pump removed-------Had machine shop fashion a wrench to get at the nasty bolts
Removed injectors so no wit is off to the folks who specialize in Fuel Pump repair
Now I am wondering what strange things I iwll run into when I do reinstall
Never got any advice on removal, however would like to hear from anyone with experience changing these pumps, on and off
Not a clue, just letting you know your post is working :)
Appreciate your interest' Got--er done, was trying to avoid mistakes so went slow.
Took it along with the injectors to a specialty shop today
Machine was built in 1978 and all indications are it has never been worked on
Probably the invoice will stop my heart All parts are priced in US Dollars
and our Dollar is trading at 1,35 Cdn to 1.00 US
Completely rebuilt undercarriage in the spring. Luckily the dollars were trading at par
/ case 350 crawler fuel pump #5
I have the same dozer. Like you, I did the entire under carriage and a lot more this spring. What was it doing that made you go after the injector pump?
It was leaking fuel around the control linkage,quite a bit . Past experience on other diesels told me to fix it now or fix it later.
(INOP) 2018 BOMAG BMP8500 TRENCH COMPACTOR (A60429)
(INOP) 2018 BOMAG...
John Deere 350 Sickle Bar Mower (A66408)
John Deere 350...
2015 RAM 4500 HD 4x4 Service Truck (A62613)
2015 RAM 4500 HD...
2015 Freightliner (A64119)
2015 Freightliner...
2006 MACK VISION (A65643)
2006 MACK VISION...
2716SFL (A61567)
2716SFL (A61567)
