Case 275 block or engine
   / Case 275 block or engine #1
bluechip
Veteran Member
Arkansas, USA
We just took a Case 275 in trade. a prior owner operated the tractor with missing loader mounting bolts and somehow cracked the crankcase. It has been welded, but still leaks oil. We are considering removing the engine and having it professionally welded, but it seems it would be a better fix if there as another engine or good block out there somewhere. The cost of a new block from case was nearly 3 grand, for a bare block!...too much! Any leads appreciated.
thanks
   / Case 275 block or engine #2
To clean the area that the leak is in and to coat it with JB weld would probably fix the leak.
Art, thats a great idea. nothing to loose so I'll give it a try. since it was welded, i'm sure it will be strong enough.. once the loader bolts are all replaced. Thanks!
Terex Loader Arm with Bucket (A51691)
Terex Loader Arm...
2012 TROXELL COMPANY  130 BBL VACUUM TRAILER (A52472)
2012 TROXELL...
2008 Ford Crown Victoria Sedan (A51694)
2008 Ford Crown...
2010 Chevrolet Equinox SUV (A51694)
2010 Chevrolet...
2013 FORD F-650 ROUSTABOUT (INOPERABLE) (A52472)
2013 FORD F-650...
2008 Ford F-750 Crew Cab Pro Patch TCM-425-135 Asphalt Patcher Truck (A51692)
2008 Ford F-750...
