Case 255
   / Case 255 #1
Hi,
I purchased a case inter-255 a couple of years ago and finally built a drag blade to use I ran into a problem. The 3pt only goes up and down when nothing is hooked up to it. When something is attached it will not go up or down. As I am new to tractors (work on many cars) I don't know where to start. I checked and repaired some linkage that was broke and noticed that some parts may be missing????. Where should I start without taking it all apart(hyd system. I do have a shop manual.
Thanks.
Dutch.:confused2:
   / Case 255 #2
Hey Dutch - I moved your post into the Case-IH section so you can get some more responses. Hope we can help solve your problems! Glad to have you at TBN!
   / Case 255 #3
HI LOOK UNDER THE FRONT OF YOUR SEAT THERE IS A KNOB THERE FOR 3 POINT PRESSURE HOPE THIS HELPS
2005 KENWORTH T300 (A52472)
2005 KENWORTH T300...
New/Unused CFG Industrial MH12RX Mini Excavator (A51573)
New/Unused CFG...
2012 UNVERFERTH 15-INCH REAR SPACERS FOR 10 BOLT HUB (A53472)
2012 UNVERFERTH...
NEW Mini Excavator Fixed Thumb Attachment (A53002)
NEW Mini Excavator...
2016 Chevrolet Impala Limited Sedan (A51694)
2016 Chevrolet...
JOHN DEERE XUV590M (A53084)
JOHN DEERE XUV590M...
