Case 220 speed increase How ?
   / Case 220 speed increase How ? #1
ngzcaz
Other than changing tire size is there an adjustment that regulates the speed of this hydraulic drive tractor ? If I have to use it for plowing snow its going to be a long day.. Great for pulling logs on a trailer but sloow.
   / Case 220 speed increase How ? #2
You can put a bigger pump on the engine. That is about it. Common problem with the Cases. Low range is too slow, High is too fast.
   / Case 220 speed increase How ? #3
Actually....... there is an alternative that most people don't think of but like anything in this world, it comes at a price.
The common complaint is that Lo Range is too slow and Hi Range is too fast. If you are willing to sacrifice some of the speed found in Hi Range, then this is something you can try.
Go on e-Bay and keep your eye open for a used Case drive motor off of a 400 series. I've seen them sell for $50.00 or even less. Remove your drive motor and install the one from the 400. It turns slower than your old one does because of the 16 inch rubber used on the 400's compared to the 12" on your 200 model.
Put the tractor in Hi Range and go plowing or mowing. Your ground speed will be about 25 percent slower in both ranges as a result of the motor swap and your torque will have increased by the same amount.
3-Point Hitch Root Grubber - Heavy-Duty Tree and Stump Puller for Tractors (A55301)
3-Point Hitch Root...
2019 FREIGHTLINER M2 26FT NON CDL BOX TRUCK (A54607)
2019 FREIGHTLINER...
2-Row Peanut Inverter (Chain Drive, PTO, 3-Point Hitch) (A55218)
2-Row Peanut...
2019 JGL 2632ES 26ft Electric Scissor Lift (A50322)
2019 JGL 2632ES...
2021 FREIGHTLINER M2106 DEBRIS BUCKET TRUCK (A51406)
2021 FREIGHTLINER...
