case 2130 4x4 not engaging
/ case 2130 4x4 not engaging #1
Banleno007
USA
Hi all I have a case 2130 orchard tractor 65hp same motor for some reason it won't shift into 4x4 . I can't understand why it stopped working , I believe that the linkages are ok. I would really appreciate any ideas anybody could give
/ case 2130 4x4 not engaging #2
You stated you think the linkage is Ok. How far down the line have you verified that? The parts breakdown shows a rod connected to a lever on the drop box. The lever fits over a shaft and is connected by a roll pin through the shaft. If the pin is sheared the lever may travel as it should but not rotate the shaft. If you have doubts, scribe a line or use a marking pen to mark the shaft and lever where they meet. Shift the engagement lever and check to see if the marks still line up or did they separate. Also, if the roll pin is still intact you should be able to push a piece of baling wire through and see it come out the other side. If the shaft rotates as it should, you might jack up one front wheel and rotate to make sure the wheel and driveshaft are still connected. If all that looks as it should and you still have no engagement, you'll have to drain the trans/hyd fluid and remove the dropbox to find out what's going on
Auger Drill Bit Mini Skid Steer Attachment (A61572)
Auger Drill Bit...
Cast Iron Anvil (A61574)
Cast Iron Anvil...
METAL FRAME FOR FERTILIZER TENDER BOX (A63291)
METAL FRAME FOR...
2021 UTILITY VS2DX 53FT DRY VAN (A59905)
2021 UTILITY VS2DX...
CASE INTERNATIONAL 125 MAXXUM TRACTOR (A63291)
CASE INTERNATIONAL...
John Deere 450 (A64119)
John Deere 450...
