Item Details
- Auction ID
- 55218
- Make
- Case
- Type
- Tractor
- Auction House
- Fastline Auction, LLC
- Model
- 2090
- Location
- Mississippi
- Horsepower
- 108
Description: Case 2090 Cab Tractor with loader. 108HP with Case 6 cylinder 504 engine. A/C blew cool not cold- seller states he has to recharge about once a year. Loader has spear and bucket, tractor is in operational condition. left rear tire has a leak, noticed some hydraulic oil around 3 point valve- oil level was within normal range, engine oil was within normal range. Seller states its either a 1982 or 83. the tractor has a Closed center hydraulic system with a open center loader valve so you have to shut the loader valve off to use three point. Tractor ran and drove as it should I noticed the shift lever was fairly lose but ran through gears as it should. Seller states clutch will grind sometimes when on incline, no grinding noticed when inspected - no mechanical inspection performed. Make: Case Model: 2090 Hours: 4937 Engine Manufacturer: Case Engine Model: 8.3L 504 Cylinders: 6-Cyl. Horsepower: 108 Enclosed Cab: Yes FASTLINE SALES REPRESENTATIVE(s) Trevor White trevor.white@fastline.com 251-215-3393 Item Location - Address: Provided by Seller Item Location - City: Lucedale Item Location - State/Province: Mississippi Item Location - Postal/Zip Code: 39452 Item Location - Country: United States
This is a online bidding auction by Fastline Auction, LLC
Case 2090 Cab Tractor with Loader
see lot description, multiple locations, KY 40010
Starting Bid: 3000.00 USD
Auction Finishes: October 07, 2025 at 04:12 PM
Click Here To Bid Now!
Happy Bidding!
Happy Bidding!
