Case 1845c No Start
   / Case 1845c No Start #1
veedub
Moretown, VT
None yet.
I’ve got an 86 1845C it’s been an awesome machine. Anyway I plowed with it three days ago no issues. I went to use it yesterday and it started right up 27 degrees out. I did have it plugged into block heater for maybe 1.5 hours before hand. It ran for maybe 10 seconds at idle and I went to drop the first lap bar and as I did it stalled. I think the lap bar was coincidence not root cause but figured I’d mention it. It didn’t spit or sputter or anything it more stopped like I had shut off the key. I went to start it back up and it will crank but doesn’t even try to start. I haven’t done any trouble shooting yet, I have my wife’s car already taken all apart and I need to get that going before I can work on the skid steer. My gut would be fuel shut off solenoid but I haven’t started to investigate that yet, just curious if anyone else has any ideas before I go down that path. I did notice that with the key left in the on position I can hear a relay click up in the warning light cluster it clicks about every 4-5 seconds. I don’t know if it normally does this I very rarely just leave the key on it’s either off or I am starting it and once it’s running you certainly aren’t hearing any relays clicking. I know if I pull out that dash light unit/gauge cluster there’s nothing on the backside it’s all smooth except a single plug for a wire harness. I have never tried to open it up to service anything inside of it but it doesn’t look super easy to split apart without breaking.
500 Gallon Poly Tank (A59076)
500 Gallon Poly...
2012 Kenworth T800 T/A Day Cab Truck Tractor (A55973)
2012 Kenworth T800...
LOT: (5) Bolt Cutters (A59076)
LOT: (5) Bolt...
SHOPMADE MANIFOLD TRAILER (A58216)
SHOPMADE MANIFOLD...
Mini Skid-Steer Stump Grinder (New/Unused) (A59225)
Mini Skid-Steer...
LOT OF I-BEAM (A58374)
