CASE 1835B - Jerky as!
   / CASE 1835B - Jerky as! #1
Simon3
SA, Australia
CASE 1835B
G'day there
We recently bought a 1835B bobcat as we used to have a 753G (chalk and cheese I tell ya!) and we are finding that it is EXTREAMLY jerky in the way that it operates the drive and loader hydraulics.
It goes from a crawl to full bore almost instantly, it is a pig to use for delicate work, the loader part is the same, it makes the bucket crowd really snap back because of this the mountings for the crowd rams have cracked and had to be rewelded.
What causing this? is it possibe that someone has wound up the Hydraulic pressure? or the park brake is half stuck on? (lever is jammed)
Thanks again
Simon
   / CASE 1835B - Jerky as! #2
Are you running the throttle too high? Seems like if you back off it will be easier to control.
2015 Ottawa Yard Spotter Truck - Cummins Diesel, Allison 6-Speed, Hydraulic Air Fifth Wheel (A53472)
2015 Ottawa Yard...
2014 Nissan Pathfinder SUV (A51694)
2014 Nissan...
Hydraulic Coupler 80 mm Pins (A52384)
Hydraulic Coupler...
2024 JOHN DEERE 6110M LOT NUMBER 56 (A53084)
2024 JOHN DEERE...
2012 UNVERFERTH 10-INCH FRONT WHEEL SPACER FOR 10 BOLT HUB (A53472)
2012 UNVERFERTH...
