Case 1816B help
   / Case 1816B help #1
cowrider
Hi,
I have a 1816B that I just got with a large leak at the drive motor. I pulled the motor and had to order a sprocket as well as the shaft because the splins where all worn. the front axles seemed to have a lot of play between its axle and sprocket so I took it out and found that the key way splintered off on one and the other way worn a great deal. looks like the key traveled to the end of the sprocket away from the motor where it didn't get full contact with the axle shaft. would putting in a longer key or a spacer put in the space help? has anyone else come across this?
looking to find a service and owner manual for this as well or at least directions on the motor repair. I did get a OM for the straight 1816 and scanned it if anyone is interested in have a copy.
thanks for any help
   / Case 1816B help #2
Not much help to you right now, I'm also looking for some manuals for the 1816. If you would send a copy of your scanned OM to vtwin7 at verizon dot net , I'll keep you in mind when I come across other manuals on this machine.
John Deere (A50322)
John Deere (A50322)
4"x8' Treated Post, 36 Piece Bundle (A52384)
4"x8' Treated...
2013 PETERBILT 365 T/A DUMP TRUCK (A51406)
2013 PETERBILT 365...
40' CONTAINER (A51244)
2006 MACK CV (GRANITE) BOB TAIL KILL TRUCK (A52472)
2006 MACK CV...
2025 New/Unused Wolverine Auger Drive and Bit (A51573)
2025 New/Unused...
