Case 1190 transmission filter
   / Case 1190 transmission filter #1
Justjake450
Louisburg, ks
Does anyone know if the transmission filter light means its just time to change the filter on a case 1190? thanks!
   / Case 1190 transmission filter #2
All the time or just when it's cold ? If all the time I would guess either the oil pick-up is restricted or the filler is.
   / Case 1190 transmission filter #3
Actually it's probably past time to change it.
Yep all the time! does the light just run off restriction so once filter is replaced it should go off on its own? I don't see a way to reset anything. Thanks for the input!
2017 FORD F-650 FLATBED DUALLY (A52472)
2017 FORD F-650...
NEW Skid Steer Bolt on Hay Forks (A53002)
NEW Skid Steer...
2011 KENWORTH T800 (A52472)
2011 KENWORTH T800...
2011 PETERBILT 389 (A52472)
2011 PETERBILT 389...
2019 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A52576)
2019 FREIGHTLINER...
INGERSOLL RAND G70 GENERATOR (A52472)
INGERSOLL RAND G70...
