Carry All Tool Storage Suggestions
   / Carry All Tool Storage Suggestions #1
FredSG
Patten, Maine
JD 4052R JD 4310, 825i Gator
Hi,
I've been building a Carry All and it's almost finished. I guess I went overboard, but I decided to go with 3/4" plywood - two sheets glued and screwed together, so that my Floor Base and Back Wall are actually 1 1/2" thick plywood. Very solid and stiff, and heavy!
The dimensions of the Floor Base are 48" wide X 34" deep; Back Wall is 48" wide X 30" high. I painted the plywood John Deere Green and added 2" X 4" boards as edging, and painted them John Deere Yellow. Eventually, I plan to cover the exterior sides of the 2" X 4" boards and exposed plywood edges with 1" X 5" pine boards that will also be painted John Deere Yellow. You can see them drying in the backgound.
I still need to add more trim boards. I'm looking for ideas on how store my tools - for the most part they will be landscaping tools, full size rakes, shovels, hand digging tools, weed "wackers" and so on. I've seen the pvc pipes others have used . . . not sure if I want to go that way, guess I'm looking for other ideas or suggestions for tool holders.
Thanks for any ideas you might care to share.
FredSG
   / Carry All Tool Storage Suggestions #2
Why not make modular. Make individual modules for different need to drop on. That way you have a basic platform to carry anything than add module for the task ahead. Looks great!
   / Carry All Tool Storage Suggestions #3
For handled tool like shovels and rakes and hoes put length's of 2 inch PVC or ABS plastic pipe vertically on back side (tractor side) of vertical wall if space permits, other wise on front of wall....
Other solution may be a pair of 2x4's bored with 2 inch holes and edge mounted to back board to form a series of drop down holes to form a "rack"....
Topzide's concept of modular units has merit if you have lots of variation in useage...
Dale
   / Carry All Tool Storage Suggestions #5
Digging it. Whats the point of a carry all if everything on it will fit in the bucket?
I find a chaisaw mount prety usefull on my machines. Oddly shaped expensive tool.
2009 INTERNATIONAL PRO STAR (A52472)
2009 INTERNATIONAL...
2019 Ford F550 Bucket Truck - Powerstroke Diesel - Auto Trans - 4X4 - 72258 miles -Altec AT40G Boom (A52748)
2019 Ford F550...
44510 (A51692)
44510 (A51692)
500BBL WHEELED FRAC TANK (A52472)
500BBL WHEELED...
CATALYST INJECTION TANK (A52472)
CATALYST INJECTION...
2022 NEW HOLLAND 266BMM 66-INCH BELLY MOUNT FINISHING MOWER WITH SIDE DISCHARGE (A52748)
2022 NEW HOLLAND...
