Flail Mower Caroni Flail Mower TM1900BSC
   / Caroni Flail Mower TM1900BSC #1
602466
Silk Hope North Carolina
New Holland TC40D
On the web site it states:
"Two rotors can be used: type A for a normal cut, and type F, fitted with twice the number of blades with respect to type A, to give a more accurate and closer cut".
Does this mean I can have both rotors installed at the same time or do I have to swap them out? If I have to swap them out is it a pain? Has anyone done this?
I have 3 acres of lawn that I use a Bush Hog RDTH-72 finisher mower on. It works great so far. I have 10 acres that I bush hog on. That mower needs to be replaced this year. I was thinking, could one machine do both?
I am purchasing the Flail for the 10 acres thats a given, but should I also purchase the extra rotor for a finish cut? I would not get rid of the Bush Hog finish mower as I don't want to be down to one mower if the flail should break.
What do you think?
Thanks;
Wally
IXLR8
Better than a Bush Hog finish mower? If thats the case no swapping rotors or mowers!
Thanks for the reply.
Wally
   / Caroni Flail Mower TM1900BSC #4
IXLR8
Wally
Sorry, I have not seen the results of a BH finish mower so I can't do a comparison to one.
2017 KENWORTH T4 CONCRETE MIXER TRUCK (A51243)
2017 KENWORTH T4...
2025 Kivel 42in Forks and Frame Mini Skid Steer Attachment (A55851)
2025 Kivel 42in...
2007 OVERLAND  TANK TRAILER (A53843)
2007 OVERLAND...
11 10 FOOT BY 5 FOOT LIVESTOCK PANELS (A53843)
11 10 FOOT BY 5...
2016 Ford Fusion S Sedan (A53424)
2016 Ford Fusion S...
GMC 3500 Extended Cab 4WD Pickup Truck - 6L V8 Gasoline Automatic (A57024)
GMC 3500 Extended...
