Careful with the draft control!
   / Careful with the draft control! #1
jwcinpk
Veteran Member
Welfare Capital of the World...KY
2009 Mahindra 3316 HST-2008 Mahindra 7010 cab - 2004 Mahindra 6000 4X4
Got my tractor back after having trouble with the hydraulics not wanting to lower. Thought I would pass on what they said was the culprit. Seems that if the draft control lever gets moved past the stops at either end it will push a piston out of a sleeve somewhere and the hydraulics will not be able to lower. So make sure the stops are tight and that you don't force the lever or let it get bent.
To quote my dealer "bad design, but he's only seen a couple that have done this"
There was no charge for the fix!
UNUSED MOWERKING SAII100 QUICK ATTACH PALLET FORKS (A51244)
UNUSED MOWERKING...
Deutz-Allis GVL Poly Corn Head (A50514)
Deutz-Allis GVL...
Kubota F3990 (A50322)
2018 E-Z Beever M12R Towable Brush Chipper (A50322)
2018 E-Z Beever...
2019 KUBOTA SVL65-2 SKID STEER (A51242)
2019 KUBOTA...
2 piece Bale Ring Feeder (A50515)
2 piece Bale Ring...
