clemsonfor
Super Member
I got one of these for free. Ran fine when i got it, then it rotted fuel lines from ethonol/sitting. I replace the lines and the carb is flodding, its spilling fuel out of carb and bogging down, only way to keep it running is switching from choke to half and back n forth as it idles up and down.
I rebuilt the carb and does the same thing.
Its a simple zama or whatever brand carb, just a diafram on one side and a nother set of gaskets onthe other and a needle on a spring. I put the new gaskets and diaphram in and needle. Still does the same thing. There is nothing to adjust!! Anythoughts???
I just had this one, maybe i have the diaphram in backwards i will reverse it?? But when i put the diaphram gasket in backwards on my weedeater when i just rebuilt it it would not run period, this will run, even up to wide open then it like bogs itself down and will stall. But can be restarted?
I genearlly am pretty good with this stuff but this one is a head scratcher to me. Its like the float is set to high, but there is no float!!!
