Carb question
/ Carb question #1
Gcorron
Lorton, Virginia
Kubota BX-25
Carb cross reference
Asking for a neighbor. He has a John Deere 240 that he wants to give to his son. Son just bought a small farm in Maine and needs a little help obtaining equipment.
Anyway, this little tractor has not run in a few years, he just doesn't need it anymore, hence the gift to his son. He was checking it out, putting in a new battery, etc. and it won't start. It runs fine on starting fluid, but will not stay lit. The jet to cut off the fuel is misshaped because he did not drain the gas.
The thing says 'FC420V-DS00' on the carb. It is certainly a Kawasaki engine. He was just going to install a new carb for his son. BUT:
As usual, John is quite proud of his parts, and wants $250 for the carb. A lot of Kawasaki folks say no problem, but they have an FC420V-DS01, but no one claims the DS00. The question to the guru's is: Is that the same Carb?
In case you need, the carb is a Mikuni. The number from the JD is M000240A595250
John says the rebuild kit has been discontinued, and by the time they added the parts, it was about 10% less than the carb! Go figure.
Any help would be appreciated.
George
I posted this on a lawn mower forum, but thought one of you guys might have an answer
/ Carb question #2
IMO, the best gift to his son would be a JD 240 with a new carb... from John Deere.
Payback for not taking good care of it for the past few years.
Just sayin....
/ Carb question #3
Just sayin....
This is not a very nice response to the original posters question.
So you are saying that God and John Deere are punishing dad for letting a JD sit unused for years?
/ Carb question #4
Gcorron,
It would appear that repair kits are available on-line for about $30. See here:
KAWASAKI SMALL ENGINE CARBURETOR KITS
Also complete carbs are also available, See them here:
https://www.jackssmallengines.com/Products/KAWASAKI/Carburetors-And-Parts-4-Cycle/Carburetors
This carb fits all these engines:
KAWASAKI : FC400V BS01 FC400V AS04 FC420V BS02 FC420V AS05 FC420V BS05 FC420V CS05 FC420V AS13 FC420V BS13 FC420V AS06 FC420V BS06 FC420V CS06 FC420V AS07 FC420V BS07 FC420V CS07 FC420V FS07 FC420V AS09 FC420V CS09 FC420V DS09 FC420V AS12 FC420V DS12 FC420V ES12 FC420V AS15 FC420V DS15 FC420V DS17 4 Cycle Small Engine
I also noticed,on the internet, that the engine has a pulse fuel pump. You should check to make sure that the pump is working before you start on the carb.
/ Carb question
Richard,
People like YOU are the reason forums are worthwhile, and I thank you much for the reply!:thumbsup:
Good info and we will look at which he wants to do, I expect he wants a new carb on it for his son. The other poster is asserting that only a John Deere carb would do, but I think we will go for Mikuni!
Thanks again for your time, knowledge, and effort.
George
/ Carb question #6
Not at all.. but their is a cost to neglect... all I'm sayin...
Neither God nor John Deere made this happen nor are either responsible. IMO
My apologies if my comments offend anyone, and do wish the OP well finding a cheaper solution that works.
/ Carb question #7
The last four digits of the engine number should be inconsequential to the correct part for the engine. The last four digits serve to identify the "brand/type" of equipment in which the engine was originally installed. They should be irrelevant to the correct carb.
iDrive TDS-2010H...
INOP/NON-RUNNING 2011 Ford F-550 Cab and Chassis Truck, VIN # 1FDUF5GT9BEB33435 (A61165)
INOP/NON-RUNNING...
2001 Eagle 24ft Equipment Trailer (A61165)
2001 Eagle 24ft...
Pallet of Forks (A61567)
Pallet of Forks...
UNUSED RAYTREE RABC44 - 44" ARTICULATING CUTTER (A62131)
UNUSED RAYTREE...
UNUSED SDLANCH SDLFP30 EELCTRIC PALLET JACK (A62131)
UNUSED SDLANCH...
