Carb problem
   / Carb problem #1
The Cub
Cub cadet 1250
Hi guys , I had the carb off my tractor and now that I've reinstalled it the tractor runs fine until I put the air filter on and then it starts to run like crap and black smoke comes out the exhaust what could be going on ? I was thinking maybe I'm sucking air in through a gas line .
   / Carb problem #2
Sounds like it is running too rich so when you put the air filter back on, you are resticting the air even more causing the engine to run even richer. Try turning the mixture screw in to make the engine run leaner.
   / Carb problem #3
Is the air filter plugged up. sometimes an air filter may look almost brand new and be clogged.
   / Carb problem #4
yep.. black smoke is rich.. .. that means too much fuel to air ratio.. if not too much fuel with no air cleaner.. but black with air cleaner.. air cleaner is restricted..
2019 PETERBILT 579 TANDEM AXLE SLEEPER (A54313)
2019 PETERBILT 579...
2000 FORD E350 CUTAWAY BOX TRUCK (A54313)
2000 FORD E350...
UNUSED LANDHONOR BS-12-2500G BALE SPEAR (A54757)
UNUSED LANDHONOR...
UNUSED FUTURE FT-13 EXCAVATOR (A54756)
UNUSED FUTURE...
2023 54' Hooklift Dumpster 20 Cubic Yard (A53422)
2023 54' Hooklift...
2020 KENWORTH W990 TRI AXLE DUMP TRUCK (A54607)
2020 KENWORTH W990...
