Capacity of Ford 1700 3 point
   / Capacity of Ford 1700 3 point #1
bdoyle
Nevada
78 Ford 1600 & 81 Ford 1700, 1980 Bobcat 720
How much weight can I carry on the back end / 3 point on my 1700 4wd? I would like to get a small backhoe attachment but I'm concerned about the weight.
Brian
   / Capacity of Ford 1700 3 point #2
I had put a 1200 pound back hoe on my old 1700 a couple of times. The three point hitch could lift it no problem, but the front end came off the ground. I had to put about 300 lbs in the loader bucket to keep it down. I upgraded to the 1920 and no more problem. Ford did sell a hoe for it my guess is it weighs about 800 lbs. good luck.
I have a line on a lw-6 and it looks to be right at 1000lbs. Oh well... The 1700 was an upgrade, 2wd 1600 to 4wd 1700. Thanks!
   / Capacity of Ford 1700 3 point #4
I have a Woods BH750. It came with a sub frame that fits Ford 1320,1520,1720, and 1920.
I'd say a BH650 or 750 would work on your tractor if you could find a used one. or maybe the new 6500,7500 will work.
I don't know what my 750 weighs as its not listed in the owners manual but I'd guess around 900-1000 lbs.
   / Capacity of Ford 1700 3 point #5
I would think the LW-6 would be ok. Could always hook it up to tractor before you buy. Does the hoe have a PTO pump.
   / Capacity of Ford 1700 3 point #6
I have had over a ton on my 1710 3 pt. A little light in the front end even with the loader but it lifted no problem. I did get a heavier top link than came with it though. Just my nervousness.
No pump right now but I plan on using one on what ever I wind up with. It does have a hydraulic tank. I don't have my loader on the 1700 yet. I was planning on building a subframe / rear loader mount to spread the load over the rear axle, engine mount and normal rear loader bolts. Would like to do a trial hook up but the BH is a few hours away and I can either put the tractor or the BH in the trailer.
2007 FORD F-750XL SUPER DUTY DUMP TRUCK (A51243)
2007 FORD F-750XL...
2011 Ford Transit Connect XLT Cargo Van (A50323)
2011 Ford Transit...
Great Plains Nutri-Pro NT-30 Nh3 Applicator (A50514)
Great Plains...
Land Honor Quick Attach Bale Spear (A50515)
Land Honor Quick...
KODIAK 10' HD ROTARY MOWER (A51406)
KODIAK 10' HD...
2017 NISSAN NV200 VAN (A51406)
2017 NISSAN NV200...
