farmeraaron
- Joined
- Dec 3, 2010
- Messages
- 6
- Tractor
- f/a 545 hm
Can a D6 pull a 25' disk with 24" blades? Thanks Aaron Mostly flat ground, sandy loam, traction is the issue here in the Northwest.
Which D6, what type of disk? There are many different D6s over the years, lot of weight and track variables. An offset or tandem disk? They do not pull the same. I can tell you that ours would not do it. But then ours is out of the 40s and only weighs 18,000lbs and has 22inch pads if I remember right. I pull an old Kielfer-John Deere 12' offset disk with 24" pans. We have mostly rolling hills and I have to use 2nd & 3rd gear. Moisture content along with steepness of the ground dictates what gear I'm able to use. My initial thought is that the disk is too big, but really need to know all the weights and type of disk to give a good evaluation.
I would add "How fast do you wan't to pull it?" to this question. I think a D6C or newer will pull it but not sure it can pull it fast enough to work well. I would suspect you need more power to get the speed up.
I have a Versatile 750 (with a 350 Cummin small block)
I would have to agree with Steve.
I think a "newer" D6 would pull it, a very rough guess would be, again depending on the model, between 28K and 38K. The problem is dozers are really not designed for towing or speed, to be going at a good speed to pull a big harrow for a good amount of time would be a teeth rattler, IMO. Unless you're on absolutely flat manicured ground...
I have a D4 sized dozer with 3 speeds, I hardly ever use 3rd cause it feels like your in the middle of an earthquake....:laughing:
Yes, I meant small cam (I thought small block did not sound right)engine has been replaced Cummins. Thanks for the correction. Sounds like a crawler may not be the answer I was thinking it was. I wanted a tractor I could use to pull my drill and disk both. The tractor wheels tend to make deep tracks in the seedbed that can be felt in following years(3). Thanks, Aaron
Is your D7 a farm cat?
