Cant shift into low range
   / Cant shift into low range #1
winniedog
L3010 HST I have no trouble shifting from mid range to hight range and back but can't get into low. It feels like the linkage may be jammed.
Anyone been through this?
Thanks for any help you can give me.
   / Cant shift into low range #2
Is your tractor in 4WD. If so put it in 2WD then try low range. Some tractors may cause binding or hard to get in low range when in 4WD. Not sure if this is your problem but worth a shot.
Yes it is in 4wd.
I'll give that a try. I'm a newbie to tractors. I leave it in 4wd all the time.
Is that ok? Thanks for your help.
   / Cant shift into low range #4
With just a little pressure on the shifter into low range, very lightly tap on the FWD/REV pedal. It might help the gears sync.
   / Cant shift into low range #5
Leaving in 4WD all the time is fine on soft ground (dirt, stone, gravel, grass, mud, etc) but not too good on hard surface like blacktop or concrete. Front and rear gear ratios are not exact and can cause binding. I believe the F to R gear ratio tolerance can be up to 5% different.
   / Cant shift into low range #6
It says HST. Thats for Hydrostatic drive. Not the same as gear binding with a Gear drive transmission. With Kubota, at least mine, you have to pump the brake pedal and clutch pedal alternately at times to get it to shift. Do not force it.
   / Cant shift into low range #7
Like the others have said, do not drive in 4x4 if you have a concrete or paved driveway. Otherwise I never take my Kubotas out of 4x4 unless I am on the road in top gear.
   / Cant shift into low range #8
I had the same problem on my Mahindra 2615HST. There were times when in 4WD low range that I couldn't shift out of low range. Had to take it out of 4wd then rock it forward and back with the HST pedal while applying pressure on the range selector to get it out. The tractor was on a gravel driveway but it was hard packed crusher run just like concrete. Also had to make sure the front wheels were straight.
   / Cant shift into low range #9
I have read on here that many Kubota HSTs are difficult to change ranges on; mine has been since new, now with about 400hrs. My technique is to shift (when possible) when the tractor is moving slightly. Else, like others have said, rock the HST pedal slightly or clutch/unclutch a few times. I think that the basic problem is that the range gears are straight cut and have no synchronizer rings, so range shifting will always be a little touchy.
- Jay
   / Cant shift into low range #10
Also, look underneath the floor board to make sure your linkage isn't bent. Mine buckled at some point and it was extremely difficult to shift. Straightened the linkage out and it greatly helped things out. Like others said, bump the FWD/REV peddle a little bit.
2012 International Day Cab Truck Tractor (A50323)
2012 International...
3 Drawer Office Desk (A49462)
3 Drawer Office...
John Deere 4020 Tractor (A50514)
John Deere 4020...
2016 Nissan NV200 Cargo Van (A50323)
2016 Nissan NV200...
CATERPILLAR 962M LOADER (A51242)
CATERPILLAR 962M...
2013 Chevrolet Traverse LS SUV (A50324)
2013 Chevrolet...
