cant get my 1943 ford 9N to run
   / cant get my 1943 ford 9N to run #1
LaDonna
1943 ford 9N
just got the old tractor to fire, now cant keep it running when I remove my hand from the carb.
   / cant get my 1943 ford 9N to run #2
Hello LaDonna. You'll proabably have to clean the carbroator. It's not getting gas. Or you could have a fuel pump problem, if it has a fuel pump. Make sure that you are getting gas to the carb, by disconectiong the gas line at the carb. Be sure to catch the gas in a can or something, so as not to start a fire. Turn it over. If no gas look for bad fuel, pump, pluged gas line, pluged gas filter, or sediment bowl. If you got gas, at the carb in let, then your carb needs to be cleaned.
David-Davies
   / cant get my 1943 ford 9N to run #3
no fuel pump when it left the factory.. it's a gravity feed system.
gas from the gas line to the carb doesn't mean gas is getting thru the carb.. removing the drain from the bottom of the carb so you can see if gas is flowing thru the float needle , etc. that's a better determination
for the heck of it check spark color.. weak sparks need rich fuel mixes.. your hand on the carb is alot of choke.
could also have a vacume leak at the carb to manifold, manifold to block, carb halves or throttle packing.... could be a cracked manifold..e tc.
soundguy
   / cant get my 1943 ford 9N to run #4
Have you checked the compression? I lost the compression on my '39 9N with the same results.
2017 Ford F-250 Knapheide Service Truck (A48081)
2017 Ford F-250...
2012 Mercedes-Benz C300 AWD Sedan (A48082)
2012 Mercedes-Benz...
Harrow Drag (A50860)
2016 Chevrolet Impala Limited Sedan (A48082)
2016 Chevrolet...
PTO-60 Pull-Behind Turf Renovator (A49346)
PTO-60 Pull-Behind...
80in HD Tooth Bucket with Side Cutters ONE PER LOT (A51039)
80in HD Tooth...
