Can't get her started...HELP!
   / Can't get her started...HELP! #1
gregfender
Marion, NC
Kubota L2501 HST
I replaced the battery on my 1070. Started right up Friday. Today, not so much. I am getting the lights, then a loud click, then noting...no lights, no more clicks. I can disconnect the + lead, turn the key...lights, then big click again, then same thing - nothing. It sounds as if something is grounding out when I turn the key. Any suggestions, similar experiences, voodoo cures?
   / Can't get her started...HELP! #2
Does your tractor have a self resetting circuit breaker? That might be the noise you are hearing and it is resetting when it cools down. Would indicate a bad short somewhere.
Fixed! Turns out it was a loose battery terminal connector. A quick trip down the parts store and $2.29 later, it's starting and running fine. It was loose enough to cause the battery to arc with the loose connector and ground out. Now to replace the switch for the lights....
YANMAR ViO45-5 EXCAVATOR (A51406)
YANMAR ViO45-5...
2024 CATERPILLAR 255 SKID STEER (A52705)
2024 CATERPILLAR...
R-134A Manifold Gauge and Hose Set (A55218)
R-134A Manifold...
2005 Dodge Caravan Van (A51694)
2005 Dodge Caravan...
NEW HOLLAND 3930 TURBO TRACTOR (A54756)
NEW HOLLAND 3930...
