Can't get a hose to come off
   / Can't get a hose to come off #1
woodlandfarms
Super Member
Los Angeles / SW Washington
PowerTrac 1850, Kubota RTV x900
Well, it has been a long day under the PT. I am chasing down reason why my PTO will not work. I have done all of Terrys suggestions (removal of PTO Actuator) and still no joy.
I am wondering / thingking that maybe my PTO hose has thrown a clot. I noticed wire coming out of the casing at one point so it is time to replace if nothing else.
This all said, I cannot get either the quick connect at the head of the hose, or the hose at the aluminum PTO block to come free.
Frankly, I broke one of my chinese wrenches on trying to free the quick connect, and cannot get the hose to come off the aluminum block. It is a pill to reach the aluminum block so I cannot get an extender on the wrench.
Any tricks to this?
Carl
   / Can't get a hose to come off #2
Did you try it when the machine was warm? Maybe that will help?:confused:
   / Can't get a hose to come off #3
Any tricks to this?
Carl,
I believe that the QD's are pipe thread and you are turning left, is that correct? I see most of the hosemen put the hose side in a vise, and use a big wrench. You could have a blockage in one of the QD's Some pictures might explain things a little better. A close up of the QD on the hose, and a closeup of the QD on the PTO manifold.
Did you ever get any pictures of your tram and PTO pump?
You have a steel pipe in an aluminum block, be careful.
2005 NEW HOLLAND DC95WT CRAWLER DOZER (A51406)
2005 NEW HOLLAND...
2011 Jeep Wrangler Unlimited 4x4 SUV (A51694)
2011 Jeep Wrangler...
Concrete Mixer Mini Skid Steer Attachment (A51691)
Concrete Mixer...
2012 FORD F150 XL SINGLE CAB TRUCK (A51406)
2012 FORD F150 XL...
UNSUED WOLVERINE TL-12-72W-72" HYD TILLER (A51248)
UNSUED WOLVERINE...
BRAWN CORPORATION ELECTRIC WHEELCHAIR LIFT (A51248)
BRAWN CORPORATION...
