CANT DRAIN BEVEL FINAL DRIVE EX50??
   / CANT DRAIN BEVEL FINAL DRIVE EX50?? #1
XCAT
Bronze Member
AUSTRALIA
new Kioti EX5310 old Daedong EX50
Hi all, just completed my 50 hr service last week on our new EX50 DAEDONG, drained the front diff oil ok, drained the LH front bevel hub ok, tried to drain the RH front hub but oil only drips out but it is still full looking in the filler hole. looking in the drain hole tried to poke small wire in but it appears to have the side of lower bearing blocking the drain hole. it seems the oil drain hole has been drilled too low in the housing.
has anyone come across this before??
regards
XCAT
my dealer came out and inspected the tractor couple of weeks ago and agreed that somthing wasnt right. i needed the tractor for some farming works and couldnt take it out of service until yesterday. the dealer came out and took the tractor back to the work shop and dropped it back today all fixed. it turns out that there is a cir clip in the lower swivel housing that the ends of were not lined up with the drain hole. the oil needs to drain through the lower bearing and out past the cir clip via the end gap of the same cir clip. :D
cheers
xcat
2015 MACK GU713 DAYCAB (A50854)
2015 MACK GU713...
2015 KENWORTH T800 MID-ROOF SLEEPER (INOPERABLE) (A50854)
2015 KENWORTH T800...
2003 Pierce Fire Truck (A50323)
2003 Pierce Fire...
2018 PJ 30+5 GOOSENECK TRAILER (A50854)
2018 PJ 30+5...
JLG MANLIFT (A50854)
2017 Ford F-550 Ext. Cab Valve Maintenance Truck (A50323)
2017 Ford F-550...
