Hi,
I just replaced the fuel line from tank to primer pump and the water separator. Prior to putting the water separator on I filled it with diesel. When pumping the primer I cannot get fuel at the pump bleed valve from the tank, or at the fuel injection pump from the water seperator filter. My neighbor thinks I may have air on both sides of the primer pump. I tried closing the inlet valve from the tank and opening the bleed valve at the fuel injection pump thinking I could get deisel from the water seperator to the injection pump. That did not work. I could not get deisel to the bleed valve on the seperator with the fuel injection pump open or closed. I believe my primer pump works as I used it successfully a few days prior when learning I needed a new fuel line. Any suggestions? Thanks in advance for your time.
