Canopy for LS4041
/ Canopy for LS4041 #1
bsentryrich
Mulkeytown, IL
2013 LS 4041
Anyone have any info on options for a canopy for R4041? I've looked at the LS website, which doesn't allude to there being a factory canopy. I have fabricated an iron/steel one in the past for my ford which I still have, however not sure I want to use it again. Any thoughts would be much appreciated, thanks!
/ Canopy for LS4041 #2
Just do a search for ( tractor canopies for sale ) and you will find about all that there is to be found. I personally like the fiberglass units, :cool: but that's just me. ;)
/ Canopy for LS4041 #3
Get in touch with the folks at Covermytractor.com They have a picture of what looks like a NH Boomer 40/50 with a canopy on it, but it doesn't come up in the search. Their fiberglass canopy looks to run around $500. I've been thinking about adding a shade for a while, so I sent them a note, and they immediately replied they could make one, and just to give them a call. R,
/ Canopy for LS4041
Thanks all! I did a website search and not much came up...will check the website listed above. I noticed that in LS tractor thread "Trailering my 4041" (or something to that effect) one of the other users had a canopy on his. I will try to contact him as well, thanks again!
/ Canopy for LS4041 #5
/ Canopy for LS4041 #6
I have a diamond plate one that I got from my dealer when I bought my tractor. After having a small cab tractor and others with canopies, They spoil you. I need to get pics of mine now that I installed lights on it. You can see it in my profile pic.
/ Canopy for LS4041
I presume if bought new from New Holland dealer (as TSO recommended) the T1530 or Boomer 40 would be a comparable fit to the LS R4041 in terms of ROPS size and canopy fitment?
/ Canopy for LS4041 #9
Yes, they LS and Boomer use a different loader, but everything else, including the ROPS appears identical, and other things like the tool box bracket that mounts to the base of the ROPS works on either.
/ Canopy for LS4041 #10
Someday I intend to build one for my LS. The fiberglass one on my CC has a gutter all the way around it with two tiny drain holes at the back corners of that gutter. The gutter drives me nuts when it rains. The holes come nowhere near to being able to drain the gutter and when it goes even slightly downhill, every bump I hit puts me under a waterfall as the water splashes out. I will build a lid with no gutters. Better a drip than a flood.
/ Canopy for LS4041 #11
Another LS owner "rolled his own" and posted about it here:
http://www.tractorbynet.com/forums/build-yourself/208946-built-steel-sunshade.html
The thing looks really solid.
/ Canopy for LS4041 #12
I ordered mine from my LS dealer, RCO Tractors in Austin, Tx, when I purchased my R4041H. It's powdercoated steel and has a rubberized liner for insulation and sound deadening. It's made here in Texas and was about $300. The same company also makes a diamond plate aluminum canopy for the same price.
/ Canopy for LS4041
Well, bought a canopy from The Perry Company in Waco TX
Powder coat LS blue
Should be here Friday
Will get some pics this weekend when down at the farm
/ Canopy for LS4041 #14
Yeah, I got mine from RCO also. I got the aluminum Diamond Plate.. Works great! Reflects the heat, and shade is good on those hot days.. I think it was around $300.00..
2012 MACK Tender Truck w/ADAMS Rear Discharge Bed Auger (A61307)
2012 MACK Tender...
2013 International WorkStar 7400 4x4 Altec AM650 50ft Material Handling Insulated Bucket Truck (A59230)
2013 International...
2017 John Deere 5090GN (A53317)
2017 John Deere...
2006 Nissan Murano AWD SUV (A59231)
2006 Nissan Murano...
12ft x 8ft Military Flat Bed (A57454)
12ft x 8ft...
Bobcat mid mount mower M60-5 60" CT2025
Bobcat mid mount...
