Cannot Reach Top Speed on John Deere 3520
   / Cannot Reach Top Speed on John Deere 3520 #1
Muncie, IN
John Deere 3520
I have a 2007 JD 3520. Over the past year, I've had issues with the brakes seizing up but managed to get this resolved by working them back and forth while I have someone else sprayed PB Blaster on the exposed area behind the back tires.
The current issue seems to be a slight lack of power in 1st and 2nd gear, but the much larger problem is while using 3rd gear. The top speed is about 11-12mph (always been 16.9-17.2 in the past) and a severe lack of power to the point where engine bogs down while trying to move at top speed.
Please help.
Thank you,
Rick
   / Cannot Reach Top Speed on John Deere 3520 #2
It may be time to have the load match re calibrated , i'm not totally sure what they do , but a tech came to my house with a laptop and fixed mine when it became sluggish . time to call deere maybe ? Hope that helps , I have the brake issue from time to time also . maybe it was the speed sensor ? its been a while .
   / Cannot Reach Top Speed on John Deere 3520 #3
Or you just aren't getting enough fuel or air. When was the last time fuel/air filters were changed?
Thanks guys, I will check airflow and fuel filter tomorrow. It has only been about 300 hours since I replaced filters. If that doesn't fix the issue, I will likely call the dealer for a possible service call.
I appreciate the info and your quick responses.
   / Cannot Reach Top Speed on John Deere 3520 #5
Keep us posted on the fix , and good luck . That's what we are here for .
2006 Volvo VNM Truck, VIN # 4V4M19GF26N396168 (A51572)
2006 Volvo VNM...
toro turf sweeper (A50324)
toro turf sweeper...
2015 HINO BOX TRUCK (A52472)
2015 HINO BOX...
2011 Manac 36245B30 43ft T/A Walking Floor Trailer (A50322)
2011 Manac...
2014 Dodge Charger Sedan (A50324)
2014 Dodge Charger...
2015 Ford Explorer AWD SUV (A50324)
2015 Ford Explorer...
