durtynacho
- Joined
- Apr 23, 2020
- Messages
- 7
- Tractor
- John Deere 4066M
Yet another topic about pulling a land plane / box blade. I have an 8FT Frontier land plane that I am pulling with a JD 4066M. It has adjustable skid shows that I have set so that it cuts more aggressively.
Anyway, I have it attached via an iMatch. I leveled the iMatch when I installed it, and then when I picked up the planer, I had to adjust the top link to level it. I was under the impression that I could just drop the planer all the way to the ground and let it rip. When I do that and begin to pull it, the planer leans forward, and the rear-end of it lifts. It definitely does not remain level to the ground, which is causing me to get crap results. Could the iMatch be the cause of this, and should I connect it directly to the 3-point instead? Or should I have left the iMatch level, and not adjust the planer? I haven't had a chance to test that because I got my ground as good as I could despite the planer leaning forward, and I've already packed it in so I'm not in any hurry to rip it all up again.
In addition to that, the skid shoes leave big gouges in the ground. This happens regardless of the shoe adjustment. To avoid that, I have to lift the planer some, but then I lose the float capability (or do I)?
On the float topic, my tractor has pins on each lift arm that either lock the arms so that it doesn't float, or unlocks them so that the implement can float up and down over uneven ground. With the pins unlocked, I can have the implement raised all the way up and it will still float upward, so do I really need to lower the 3-point hitch all the way down in order to activate float?
I am hoping to just get some feedback so the next time I need to use it, I have better results. Seems every video I watch, the operators just drop the implement and it works great for them. I am not even coming close to having that experience, which I'm sure is operator error.
Thanks in advance for any replies I get!
