Can you identify these vehicles?
   / Can you identify these vehicles? #1
TractorGuy
Elite Member
N. FL
John Deere 4310 CUT, Ford New Holland 575E Industrial Backhoe, John Deere F725 Front Mount Mower
My nephew spied 3 of these in Atlanta. Anybody know what they are?
   / Can you identify these vehicles? #3
Agree with MossRoad, my guess is GM based, there's a Bowtie on the front! No, really, Pontiac Fiero, as the look to be rear engine, but not a VW type front suspension.
Ive seen a low slung VW based buggy used to put the reflectors on the yellow lines, driver uses cordless drill to buzz them down, box of reflectors sitting in passenger seat...
   / Can you identify these vehicles? #4
Do you have any other pictures of them or of the trailers on the back?
Were these at a race track or where were they seen?
They look to me like they would be used to heat up and put down something, my first two guesses would be hot tar to fill in cracks, or a steam pressure washer, except that if it was a steam pressure washer I would expect there to be a visible water tank on there and heavier wheels in the back.
I could see them being used for striping as well, but it would not likely be for long distances on the road as those are usually a big trucks that is set up to do that, this would be for something more specialized.
Aaron Z
   / Can you identify these vehicles? #6
I don't see any spray heads. Probably for putting down that thick vinyl striping hence the propane tank as they are applied hot and the pavement needs to be clean and dry.
Ron
I could see that, but I don't think that would go with the large tank in the left rear corner of the trailer as usually the guys putting down the vinyl striping just have weed burner type torches attached to 100 lb propane tank rather than this which appears to have a pair of 100lb propane tanks attached to some kind of L shaped heating device that is at least 3 ft wide, 6 ft long and 4 ft tall on a trailer that is attached to a dedicated vehicle via a 2 point hitch and is equipped with swivel rear wheels so it can be backed up without needing to worry about jackknifing and always staying straight behind the tow vehicle.
To me, it looks like something specialized to be used for a dedicated purpose off of the public roads and away from general vehicle traffic.
That is why my first guess would be something related to a race track.
Aaron Z
   / Can you identify these vehicles? #7
Or else the person who normally drives it likes Chevrolet. It appears that only the first one has that on the front.
Aaron Z
   / Can you identify these vehicles? #9
I noticed that also and thought maybe it was a hot water pressure washer for cleaning where the stripe goes. Or maybe it is for cleaning guardrails.
Ron
Looking closer, I almost wonder if the lower part of the L-shaped heater is a open top tank and the upper part is a chimney with heating coils going around it ( inside the red outer casing).
Aaron Z
   / Can you identify these vehicles? #10
Looks like something from Mad Max Beyond the Thunderdome
2017 Mitsubishi Outlander Sport SUV (A53424)
2017 Mitsubishi...
UNUSED RAYTREE RMT48 HYD TRENCHER (A54757)
UNUSED RAYTREE...
Oil Well Pump Jack with Motor (A52377)
Oil Well Pump Jack...
2019 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A54313)
2019 FREIGHTLINER...
2023 BOBCAT T770 SKID STEER (A52705)
2023 BOBCAT T770...
UNUSED LANDHONOR 11' X 19' ALL-STEEL CARPORT (A54757)
UNUSED LANDHONOR...
