Can you ID this tractor?
   / Can you ID this tractor? #1
DJLX
East TN
JD 2210
They have been using this to till the clumps out for seeding. Actually they just make smaller clumps with it then roll out this netting/ straw material which I believe has seed in it. After a couple of weeks the grass starts coming up through it.
   / Can you ID this tractor? #2
Looks like a 790 or predecessor. Green ROPS with rounded corners is one clue /forums/images/graemlins/smile.gif
   / Can you ID this tractor? #3
A mid-80's model 750 or 850?
It is a 770 but that is all I know. You guys are good!
   / Can you ID this tractor? #5
The mid 80's tractors or 50 series had an open hood cover on the sides. This one is enclosed so the motor is not visible which they started to do on the 70 series. Because of its smaller size ag tires in the rear and the higher operator position relative to fender height, I would of guessed it being a JD 670
   / Can you ID this tractor? #6
</font><font color="blue" class="small">( It is a 770 but that is all I know. You guys are good! )</font>
DJLX,
I really don't believe that's a 770. Maybe a 670 but what's pictured I believe is way too small to be a 770 (I have a 770).
Arrow,
I wasn't aware the 50 series didn't have side engine covers.
I will go on a hunt tomorrow and take a close up. It is possible I saw the numbers wrong from a distance.
Here is the close up. It is a 770 and has a Landpride tiller on the back.
   / Can you ID this tractor? #9
</font><font color="blue" class="small">( Here is the close up. It is a 770 and has a Landpride tiller on the back. )</font>
I stand corrected. /forums/images/graemlins/crazy.gif Pretty embarrassing since I have one.
It just looks so small in that first picture. The hood doesn't appear to be taller than the waist of the guy that's standing there (but maybe he's 7' tall). I'm not a big guy but I thought the hood was higher. I guess the FEL on mine must make it seem larger (and taller).
Anyway, I still love mine. I was moving dirt for the neighbor yesterday. A full load of wet clay in the bucket and a 6' box blade with full load in tow. Moved a lot of dirt in a hurry with no problems.
Brian
   / Can you ID this tractor? #10
Unless someone changed the decals on the hood, I also would of guessed incorrectly. I always thought one could put a 24" rim out back on the 700 series. Of course I can be wrong, but this one doesn't look like it could clear a 9.5x24" tire. I think the tractors looked and ran way cooler with the exposed engine but heck ,they're even getting compact tractors to look like swoopy cars. /forums/images/graemlins/mad.gif
2025 New/Unused 72in Skid Steer Sickle Bar Mower (A51573)
2025 New/Unused...
2020 GENIE TZ-34/20 TOWABLE MANLIFT (A51242)
2020 GENIE...
2019 JOHN DEERE 5090M LOT NUMBER 91 (A53084)
2019 JOHN DEERE...
WB Mower (A50120)
WB Mower (A50120)
2014 CASE 586H FORKLIFT (A52576)
2014 CASE 586H...
2007 INTERNATIONAL 7400 DT466 SFA 4X4X CHASSIS TRK (A51406)
2007 INTERNATIONAL...
