Can you help? Need pics of 870 mmm attach linkages
   / Can you help? Need pics of 870 mmm attach linkages #1
MGADon
CT
JD 870
Looking for a big favor. I'm assembling the parts needed to attach a mid mower to my 870. I have the opportunity to buy a lot of this used, but I'm unclear about what I'm buying and how it's attached. Does anyone have an 870 with mmm who can post pictures of the attachment hardware? I would especially benefit from seeing the pieces that work with the 3 pt lift arms at the extreme rear, underside of tractor. Any help is greatly appreciated.
Don
   / Can you help? Need pics of 870 mmm attach linkages #2
Go to your JD dealer and ask him to show you the parts manual for that particular mower. That will illustrate everything you need. Also you might ask the guys who work in the shop assembling the mowers. Every mower comes with a diagram.
   / Can you help? Need pics of 870 mmm attach linkages #3
Check out this thread... 670 MMM attachment help.
The pictures in that thread are for a 770, but should give you the idea. Also you can search out the mower deck on the JD parts site and find all the bits and pieces there.
Thanks, I have pics of the 870 hardware and it's similar, but not the same. The 3 pt lift arm pivot pins on my 870 are only about 2 inches long, on the 770 they are 6 plus inches long. The mmm lift hardware slides onto the long pivot pins on the 770. For the 870, I think I need to get longer pins. Looks like I should see the dealer's microfiche.
Don
2014 Chevrolet Impala Limited Sedan (A51694)
2014 Chevrolet...
Cub Lo-Boy 154 Tractor (A50515)
Cub Lo-Boy 154...
2021 FORD F-150 XL EXT CAB TRUCK (A51406)
2021 FORD F-150 XL...
2013 Nissan Sentra Sedan (A50324)
2013 Nissan Sentra...
2013 VOLVO VNM TANDEM AXLE DAY CAB (A52141)
2013 VOLVO VNM...
