We all know on a GN you are supposed to have 20-25% on the tongue and 10-15% on the tongue on a tag. If the tongue is too light the trailer will sway like crazy.
What are the consequences of having the tongue too heavy provided you are not overloading the hitch or the tow vehicle? Any adverse towing affects?
I am wanting to load my backhoe as far forward as possible on a pintle hitch trailer to help reduce the load on the trailer tires. The pintle hitch is rated for 15k vertical load and it is on a Kenworth.
Tongue weight I am aiming for would be around 5,000 lbs I am guessing. Loaded more towards the back of the trailer I went across the scales and the tongue weight was 3,040 lb and I had 20,920 lb on the trailer. The trailer axles are rated for 21k. It fell right in the 10-15% range but I was thinking if if I moved the machine forward 18-24" I could take a couple thousand pounds of the trailer axles and not have them right at the max and hopefully make them and the tires last longer.
