Can you have too much Lovis Hyguard in a 3320
   / Can you have too much Lovis Hyguard in a 3320 #1
BloomingtonMike
Platinum Member
John Deere 3320
So I checked my tractor warm? (started then turned it off) and the hyd fluid was low. Dumped in some and still low. Dumped in about a gallon. Check it today and the level is about double the checked box on the stick. Seems to run great. Should I get some of that fluid out of there? If so how do I drain some?
   / Can you have too much Lovis Hyguard in a 3320 #3
Are you sure the 3PH and and the FEL where lowered all the way when you checked the fluid?
   / Can you have too much Lovis Hyguard in a 3320 #4
Make sure your 3 pt is down and loader is to. you should alway check you transmission oil when it is cold and if you can't wait that long let it sit for 15 mins. to let all hydro oil to settle.if you over fill the transmission you can damage it.let me know how it went and how is you light switches coming.
matthew3120
   / Can you have too much Lovis Hyguard in a 3320 #5
I hear air in my loader when I lift after using the hydro hard. Dealer said it's OK to overfill by a couple of qts. It didn't help my situation, but hasn't hurt anything either.
I am about 1qt over now. To be honest it ran just fine even with a gallon over. Better safe than sorry with this big $$$ machine.
   / Can you have too much Lovis Hyguard in a 3320 #7
As soon as I get a direction to look, mine is going in to the dealer. I have air getting in somewhere. I hear/feel it in the loader after driving, especially with a load.
If I work the hydro hard like pushing snow/dirt, I really notice it when I lift the loader...
   / Can you have too much Lovis Hyguard in a 3320 #8
If you "skip" the part that says "Park machine safely. (See Parking Safely in the SAFETY section.)" you will miss the part that says: stop machine on a level surface...lower attachments to the ground...
These things matter when you check fluid levels, especially lowering all attachments to the ground.
2006 Ford Crown Victoria Sedan (A50324)
2006 Ford Crown...
2015 Infiniti QX60 SUV (A50324)
2015 Infiniti QX60...
2003 Ford F-350 Dump , VIN # 1FDWW36P63EC81092 (A51572)
2003 Ford F-350...
2014 GMC Sierra Pickup Truck (A50323)
2014 GMC Sierra...
7022 (A50322)
7022 (A50322)
2010 HEIL TOKEN TRAILER (A52472)
2010 HEIL TOKEN...
