Can you convert an L3301 to an L3901?
   / Can you convert an L3301 to an L3901? #1
vanguard
Bronze Member
Raleigh, NC
2014 Kioti DK45SE
As far as I know the only difference between the L3301 and the L3901 is the tuning. I think it's actually software and every single part is the same.
Am I right on that? If so, can you convert an L3301 to an L3901 and save a few thousand dollars?
   / Can you convert an L3301 to an L3901? #2
I don't have an answer but want to hear what people say...
I asked the salesman while I was there kicking the tires and he told me it wasn't approved by the government. I said, "It seems like the sort of thing diesel truck owners do all the time. They buy a tuner and have the computer dump more fuel."
Neither of us knew what was ok and what wasn't.
I'm not sure how much I care about government approval. If it's the same hardware but detuned on the 3301 I wouldn't feel guilty at all getting the extra HP. I'm probably missing something.
   / Can you convert an L3301 to an L3901? #4
Are all the other parts the same such as the radiator, amount of air coming into engine, exhaust, etc? Those could be different with a higher horespower I suppose
   / Can you convert an L3301 to an L3901? #5
So far I have never needed more HP... I got R4 industrial tires and I either lose grip or dig a hole... Guy at work replaced a chip on one of our trucks, better HP/performance and better mileage... go figure!
   / Can you convert an L3301 to an L3901? #6
I don't know, but we are all sure interested in what you find out.:D
I wonder if the injector pump may be different?
   / Can you convert an L3301 to an L3901? #7
Not up on the new models. But the prior ones used a different PTO configuration too in the gear models. That alone was enough for me to spend the extra and get the 3400 over the 2800
   / Can you convert an L3301 to an L3901? #8
Interesting! The L3200 used to have a 91.5 cubic inch engine, while the 3800 had 111.4 cubic inches. Now both the L3301 and L3901 have the 111.4 cubic inch engine. The 3200/3800 were indirect injection, while the 3301/3901 are direct injection.
I wonder if the L3301 is just detuned somehow? Seems like a cheesy way to do it, but then again maybe this is an opportunity for a smart person to get 6 extra HP out of their 3301...
   / Can you convert an L3301 to an L3901? #9
Its nothing new and nothing unique to kubota. Mfgs have been doing it across the board for years.
Sometimes the same engine might span 3 HP ranges. A detuned one, a std one, then one with a turbo.
   / Can you convert an L3301 to an L3901? #10
Yep. One of the brands we represent has the same engine in 74, 92, and 125hp variants. We've gone as far as taking an ecu from a 92 and put it on a 74. Made a huge difference. Don't know if we reached the full 92 but it was close. The 124 has a bigger turbo and intercooler.
UNUSED KIVEL SKID STEER QUICK ATTACH PALLET FORKS (A51244)
UNUSED KIVEL SKID...
10' Poly Feed Trough (A50515)
10' Poly Feed...
New/Unused 20ft Farm Metal Driveway Gate (A48837)
New/Unused 20ft...
2017 Bad Boy Outlaw XP 61in Zero Turn Mower (A48082)
2017 Bad Boy...
5' X 20' 3/8" THICK STEEL PLATE (2) PIECES (A51244)
5' X 20' 3/8"...
KUBOTA U55-5 EXCAVATOR (A51242)
KUBOTA U55-5...
