Can you add draft control
   / Can you add draft control #1
LabLuvR
SC
Kubota MX5400
My Kubota does not have draft control is that something that can be added? I doubt it can be but wanted to make sure. Thanks!
   / Can you add draft control #2
You would need to check with a dealer for adding draft control. I doubt that it is available, but possibly. I have never seen aftermarket draft controls, but they might exist.
   / Can you add draft control #3
I'm not sure what tractor you have but most tractors you can go back and add draft control to them. Most brands carry the same draft control they would put on at the factory.
   / Can you add draft control #4
I don't know what tractor you have, but Massey Ferguson offers draft control in a kit that can be ordered any time.
   / Can you add draft control #5
My NH has the slot cut out in the sheet metal where the draft control lever would go, next to the 3pt lever..
Remember the old days of ford / ferguson when draft was standard.. and position control was the upgrade..
Soundguy
   / Can you add draft control #6
Yes, I do. Now most people that buy small tractors just want to mow and use them like big lawnmowers. They don't ever plow.
   / Can you add draft control #7
I have added draft control to my L3130 with out any trouble. This really does help plowing and box blading. So which model do you want to add this to?
I wish you well,
Gil
   / Can you add draft control #8
You can add draft control to the L3710. I have had it and still have it on my International. I have little use for it even with boxblading. It can be very useful for some.
20 YARD ROLL OFF CONTAINER (A45046)
20 YARD ROLL OFF...
2022 Deere 26G (A44501)
2022 Deere 26G...
2012 FORD F550 UTILITY TRUCK (A43004)
2012 FORD F550...
Mitsubishi FG35 Forklift  8,000lb Lift Capacity, LP Gas (A44789)
Mitsubishi FG35...
2018 NRG NIRG TRAILER (A45333)
2018 NRG NIRG...
2014 Dodge Charger Sedan (A44572)
2014 Dodge Charger...
