Can someone run a serial# for me?
   / Can someone run a serial# for me? #1
exiled
North Al.
I'm now in the works of buying this tractor. JD has already have the loan approved. Just the salesguy and I are not eye to eye on the downpayment. Anyway I'm going to use this time to try to research this unit if possible. If anyone could run the serial I would greatly appreciate it. Serial# LV5300E631378. Any info is appreciated.
While I have yalls ear. I'm new to the tractor relm of things. Does folks upgrade their tractors for performace or it just generally just add attachments leaving the tractor basicually stock?
   / Can someone run a serial# for me? #2
Build date March 12 1997, no warranty claim except for a small $15.00 switch. You shouldn't need to hotrod this machine, if you do then you should have gotten a larger tractor to begine with. If I can help let me know.
   / Can someone run a serial# for me? #3
I think common upgrades are additional worklights and canopys to keep sun/rain off you. I agree with gamble, generally no sense trying to get more hp out of the motor.
gamble thanks very much. Is it possible to find out if it was a local tractor? Well local to Alabama.
I was wondering on the performance cause I've noticed this engine has been used for a long time in many models and very series it comes with 3-4 different horsepowers. I really cant find what JD did to get the extra 10 hp from each model. For example the 5300 a 60hp 2.9L has the same engine as the 5310 65hp 2.9L. The 03 series is the same way. Yes I should have gotten the 5310 but it's just not in the cards.
   / Can someone run a serial# for me? #5
Only prior owner was in Crossville, AL...so it is a one owner machine.
Thanks I appreciate that.
UNUSED PE Industrial Stretch Wrap Rolls (A53117)
UNUSED PE...
1 pallet of miscellaneous PPE (A53117)
1 pallet of...
2013 Audi Q7 AWD SUV (A51694)
2013 Audi Q7 AWD...
VOLVO QUICK COUPLER MAST W/ 72" FORKS (A52705)
VOLVO QUICK...
2025 Wolverine EX-66-84L Pallet Fork Extensions (A53117)
2025 Wolverine...
2014 SHOP BUILT  DISCHARGE MANIFOLD (A53843)
2014 SHOP BUILT...
