Can someone Please help, I am lost on this, My mower gears are reversed...
   / Can someone Please help, I am lost on this, My mower gears are reversed... #1
NHmitch
Platinum Member
SW New Hampshire
Bolens G154/IsekiTX1300F
Hi,
I have an MTD 20hp riding mower, and I have been trying to take very good care of it, since I cannot afford a new mower right now. It is about a 2001 model, and my this past week, it seems like everything went bad. I had to replace the battery, the drive belt, and the starter just started smoking. That is really not the odd issue. I was mowing with it today, after replacing the drive belt that had slipped off. I put it back together exactly how it had been put together since I've had it, and it worked great for an hour. I went up a hill, got stuck, and the drive belt slipped off again. The odd part is, I put the belt back on, and when I went to shift, the gears are reversed. There are two forward speeds(forward slow, and forward fast) and one reverse along with a 10 speed selector lever on the side. Now when I put the gear lever below the steering wheel into forward low, or forward high, the tractor is in revers. When I put the lever in reverse, the mower goes forward. It is not grinding or slipping. Any idea on what could have happened? I am completely lost on hw to repair this. I know how to fix the slipping belt. It needs new belt guides, but the drive being reversed baffles me. Any thoughts? Thanks!
   / Can someone Please help, I am lost on this, My mower gears are reversed... #2
Double check the drive belt. It sounds like you have it installed in a figure "8" which would reverse the drive.
   / Can someone Please help, I am lost on this, My mower gears are reversed... #3
That fixed it! Thanks for the help, I feel really dumb, but when I put it back on I couldn't tell or see under where the belt was.. Thats a big relief!
2006 FREIGHTLINER CL120 DAY CAB (A53426)
2006 FREIGHTLINER...
2017 DRAGON 150 BBL ALUMINUM TRAILER (A53843)
2017 DRAGON 150...
2007 FORD F-550 XL SUPER DUTY DUMP TRUCK (A51406)
2007 FORD F-550 XL...
2016 Nissan Altima Sedan (A51694)
2016 Nissan Altima...
2005 Wells Cargo CEW202 20ft T/A Enclosed Concession Trailer (A51694)
2005 Wells Cargo...
WHISPERWATT DIESEL POWERED GENERATOR (A53843)
WHISPERWATT DIESEL...
