Can rear ballast be dangerous?
   / Can rear ballast be dangerous? #1
Deepdrop
Bronze Member
Lebanon, New Hampshire
Kioti CX2510 (2021)
I am a new tractor owner and I recently posted because I had a disturbing incident where my rear wheel came off the ground when I was lifting a heavy rock using the grapple on my Kioti CX2510 with loaded tires, and no ballast.
I learned from the discussion that it's important to have rear ballast when lifting heavy loads in the front.
So, my ballast rack and weights arrived and I put on 336 lbs of weight on the rack today. It got me thinking about whether this could be dangerous when I'm NOT carrying heavy front end loads.
Should I keep the weights off when I'm just doing lightweight tasks? Is there a risk of actually causing the front wheels to lift up and possibly tip over backwards?
I ask this because the tractor just felt different with the weight on today. Going up an incline with the ballast on definitely made me think. I decided to back up the incline because it felt like going forwards could be a little iffy.
If anyone could clarify how to manage rear ballast depending on tasks, I'd be grateful. Do you leave it on all the time? Maybe I just need to get used to the new feel?
Thanks very much.
   / Can rear ballast be dangerous? #2
I don't see the ballast being an issue. Most of the time I have a mower on the back of my tractor. I think it outweighs my ballast box. If you attach to a load on the rear incorrectly you do run the risk of flipping the tractor. that's why when pulling you should connect below the rear axle. I tend to leave the ballast on my tractor when not mowing. It helps counteract the loader.
   / Can rear ballast be dangerous? #3
Loaded tires are good for traction but 3pt ballast is much more effective for loader. Keep the 3pt ballast low and with little side to side play on the lower arms.
   / Can rear ballast be dangerous? #4
It would take a lot more than 300 pounds to make it tip backwards. Even if you did manage it flipping all the way over would be close to impossible because the weight will hit the ground before that happens.
   / Can rear ballast be dangerous? #5
You did just fine, loading weights on the rear of the tractor. It will help stabilize the tractor during FEL and grapple loads. And no need to be constantly adding and removing weights. For my rear weights, i just pick up my 520lb box blade which can stay on the tractor for many weeks at a time. Its the perfect counterbalance for safety. And your tractor should go up hills without any problems.
   / Can rear ballast be dangerous? #6
Thanks very much.
No, not an issue. Even with your small tractor the 336 lbs is likely not enough rear ballast for really heavy FEL work. See your manual. My manual calls for 1100 lbs on the 3pt. You can leave it on all the time, or you can take it off. Up to you. if I am using another rear implement, obviously the rear ballast is off, and I will have to rely on the ballast of the fluid in my rear tires to pull the implement. Sometimes not near enough. If I go to pick up a big rock or log, you can bet my rear ballast is on. The rear tires coming up off the ground is NOT a good feel, and you should NEVER get used to that. It is dangerous as your front axle pivot point can pivot either way instantly and unexpectedly. Rears in the air: "Danger Will Robinson"... :)
Thanks for the reassurance.
The manual mentions the need for using appropriate ballast but doesn't give any numbers. Not real helpful.
Maybe I'll add some wheel weights also.
   / Can rear ballast be dangerous? #8
I might add, even rear ballast does not guarantee safety on some heavy loads. The only time my rear wheel ever left the ground, was while picking up a pallet load near my max loader weight, unloading off a delivery truck, and even with good rear 3pt counter weight, both rear wheels left the ground for a split second until such time the front weight was lowered to 18" above ground. At that height, everything became stable again. So if at all possible, always keep your heavy front loads close to the ground and no sharp turns.
   / Can rear ballast be dangerous? #9
It may be counter intuitive but using the ballast can reduce rutting in grass/soft ground. It removes weight from the front axle (from the lever effect), so the narrower front tires are less likely to dig into soft ground. With no ballast, any load in the FEL reduces the pressure of the rear drive tires on the ground. They may be "touching" the ground but are more likely to spin as the lose traction and rip up the sod.
Adding wheel weights doesn't reduce the weight on the front axle, just adds more weight to the back end at a lower center of gravity. Better for stability on slopes
Once moved a heavy weight with my loader, without ballast Things were fine until I hit some wet ground. The rear wheels just started spinning up mud. Was able to put it in 4WD, and crawl out of it , basically driving with the front axle only in contact with the ground. Never did that again.
Same thing for braking. In 2WD the rears have less traction without ballast, to stop the tractor. Going down a slope can be very dangerous with a loaded FEL and no counterweight.
My GC2300 is a lot lighter than your Kioti. It still has the 300# boxblade on it at all times when not using the chipper or snowblower.
   / Can rear ballast be dangerous? #10
I personally do not like using my tractor ( RK24 ) without having ballast on the rear, I have a factory mounted back hoe that weighs in at 741lbs. the rare time that I do take it off the traction and loader workability are greatly reduced, I feel much safer and get more done in shorter time with the ballast.
Much of the work I have done around my small property would not be doable without that weight on the rear, I use the back hoe to do a fair amount of work to include moving trees that I have felled and cut up to the burn pile then digging out the stumps. it takes a while due to the size of the trees, without the BH on the rear I would not get it done without a great deal more manual labor.
2004 Ranger 195 VX Comanchee Bass Boat with Trailer (A51573)
2004 Ranger 195 VX...
HYUNDAI 30D-9 STRAIGHT MAST FORKLIFT (A51246)
HYUNDAI 30D-9...
Guard Rail Pieces (A51692)
Guard Rail Pieces...
Miller Trailblazer 250G 4,000 Watt Welder/Generator Set (A51691)
Miller Trailblazer...
