Can lights and Ceiling Fans in a New pole barn?
   / Can lights and Ceiling Fans in a New pole barn? #1
goodoleboy
USA
Still looking since thats half the fun!
Can you guys give any advice on what type of lighting would be good for a new workshop..
The building is 30x50x10 I was thinking of adding can lights becuase they are farily cheap $7 each and provide very attractive lighting vs. a flourescent style light which really give me headache when I am under one for a while.
The ceiling height is 10 feet tall..I was thinking of mounting the lights in 4 rows with 10 lights in each row..Total of 40 can lights.Do you think this will provide suffiecent lighting?
Also do you think multiple celing fans 5-6 would be better than one large fan? I dont have any heat or a/c in the building so this will be my only source of keeping cool in the summer.
   / Can lights and Ceiling Fans in a New pole barn? #2
Hmmm...40 lights at 60 watts each is 2400 watts (40*60=2400). 2400 watts on a 120V circuit will be pulling 20 amps (2400/120=20). I'd think you'll need to put in at least 2 circuits just for the lights.
What wattage are the cans rated at?
Hi, unsure of the wattage..I was thinking whatever will handle a standard 100watt lightbulb..
As in two circuts, does that mean two "breakers" in the fuse box? I am having my fahter in law help me do the wiring portion so I dont know much about elctricty.
   / Can lights and Ceiling Fans in a New pole barn? #4
...I was thinking whatever will handle a standard 100watt lightbulb...
Using 100 watt bulbs will mean that the 40 lights will be drawing 33.3 amps. This will almost certainly require two 20 amp circuits.
Yes, circuit can be thought of as a breaker in the fuse box.
Is your father in law an electrician? You'll need to be sure you are following local electrical code for safety sake, and also to pass any inspections that may be required. Code may limit the number of lights you can install.
Yes he was a electrician in another state years ago..He is not in my state. Ill have to call the building inspector and give him a run down on my plans and see if its ok for code..I may just do two rows along the walls if the number is a problem.
   / Can lights and Ceiling Fans in a New pole barn? #6
There are folks who know a lot more about this stuff than me, but I put some can lights in part of our "barn" recently. The main issue with can lights is they don't put out as much light due to being recessed- that may not be a big deal if you have task lighting where you need it. I ended up putting cans in the home gym area and just used keyless incandesencts in the shop portion which put our more light (not attractive, but cheap and functional). Flourecents use less juice and put out a fair bit of light and can be purchased in different color temperatures, some of which may not bother you as much.
   / Can lights and Ceiling Fans in a New pole barn? #7
If you need to keep cool in the summer, the use of incandescent bulbs will be the rough equivalent of a 4000 watt heater running whenever you have the light on.
   / Can lights and Ceiling Fans in a New pole barn? #8
Our house is 2,425ish square feet. We have 80+ can lights in the house and on the porches. :eek: We also put in task lighting under the cabinets in the kitchen and the utility room. Our ceiling are 10 feet tall.
There are lighting "rules" for how much light(lumes) you need based on the ceiling height. Google should find you the rules pretty quick. I looked up the rules and then went beyond. I don't want a dark house. :D And I'm glad I did it since my eyes are getting worse and what use to be bright ain't as bright as it used to be.
In our Kitchen which is about 16x16 without the cabinets and appliances we have off the top of my head 9 can lights, four task lights, and the light from the ceiling fan. Usually the task lights and 8 can lights are on. The task lights have been burning for 24 hours a day for 3 years. Still have not replaced the tubes. :eek:
Our bedrooms and study are 16x16 or 12x12 and they have four canned lights plus the ceiling fan light. We usually don't use the ceiling fan lights they just came with the fan. There is no problem with lack of light with this setup.
We get more than enough light from these cans. They are running either R30 or R40 CFI bulbs. But you can use the cheaper CFI bulbs. I THINK the cans were rated at 65ish watts maybe they went to 100 but you need to check what yours is rated. I would stick with the CFI bulbs the last longer, don't put out that much heat, and use less power. The bulbs we are using are 13-15 watts. The only incandescent bulbs we have is for the vanity mirror in the bathroom. When the wifey turns the light it heats up the room quick.
Regarding ceiling fans. I would get more rather than one or two big ones. More fans should be quieter and would move the air where you are working. You might be able to work with less fans running. I would also get the fans with a light. A problem with cans is that ceiling fans will be LOWER than the lights. When the fan is turned on you can get flicker/shadows from the fan. If the fan has a light it can be turned on to lesson/negate the flicker. This has not bothered us I think because we have so many lights.
Also some cans are rated to have contact with insulation while others are not. If you have insulation that will contact the light can make sure you get the correct can. Light cans also leak air. Some cans are better at this than others. This may not matter in your garage. Just putting the info out there.
I thought I was going overboard with the cans. But I figured I could always use bulbs with less wattage if there was TOO much light. If there was not enough light it was going to be very expensive, dirty and time consuming to fix. We have not regretted putting in 80+ cans. :D
Later,
Dan
   / Can lights and Ceiling Fans in a New pole barn? #9
Window fans would provide much cooler air than ceiling fans. Ceiling fans will just blow down the hot air that rises to the ceiling and they are especially bad if you have an uninsulated metal roof.
Can lights put out a lot of heat and the light is very condensed in small areas leaving other areas with insufficient light. I recommend flourescents that you can get in different color temps that will be the same as incadescent lights. You may also want to use the CFI bulbs. They will be much more energy efficient and save on wiring costs also.
   / Can lights and Ceiling Fans in a New pole barn? #10
Work shop or barn?? Reason is, cans tend to get a bit warm. Barns generate a lot of dust. Dust and heat seem to be too good of friends once in a while and tend to fire up. I could feel your pain about flourescents, i have the same problem as well, but CFL's seem to be getting better and better, there are even cold start ones that will work down to -20, or so they say. Will say for sure later, i am liting the goat pens with them. Another reason is because an incandescents are hot and if broken could lite a fire in the hay. Heard of 1 fellow who swears by CFL's in trouble lites, saves on arm burns when working in close proximity and do not pop as easy if get wet.
2006 John Deere 997 ZTrak 72in Zero Turn Mower (A42744)
2006 John Deere...
2016 Ford Explorer AWD SUV (A42744)
2016 Ford Explorer...
2017 Ford Explorer AWD SUV (A42744)
2017 Ford Explorer...
2013 LONE STAR  18FT UTILITY TRAILER (A45333)
2013 LONE STAR...
2015 TYRSOL PNEUMATIC TRAILER (A45333)
2015 TYRSOL...
14' Harrow Cultipacker (A42021)
14' Harrow...
