dwelshans
This new thread is a bit of a continuation of a discussion started on LD1's "New L4600...anyone look at one yet????" http://www.tractorbynet.com/forums/kubota-buying-pricing/232819-new-l4600-anyone-look-one.html. LD1 had some interesting information regarding the FEL capability on the L4600 .vs. the L4400 FEL.
My situation: I have basically handled my pasture maintenance needs with my 27 year old Hinomoto E280. Since the E280 can not "effectively" handle an FEL, I bought (3rd or 4th hand) a dedicated loader (Ditch Witch 400LD) to handle the normal FEL stuff as well as deal with our fairly recent conversion from square bales to round bales (just can't afford squares anymore in my area). We purchase about 30 round bales (typically 5' wide x 5.5 tall...run about 1200 lbs.) a year ...loaded by supplier on my trailer in field on day of cutting...offloaded by me at our place and placed under cover, then pull out 1 to 4 every so often and rebale into squares for daily usage. The off-loading, storage and rebaling take place on a level concrete pad. Bales stacked 2 rows high max. on trailer...height from ground to center of top row is guesstimated at 115". My shed cover height is 13', so I only stack bottom and 2nd row (about 84" from slab to center of top row). I am not, and do not plan, to be running across pastures of varying slope/softness with the tractor/loader/round bales.
Problem is my E280 has suffered a potentially $$$ problem and I am looking to consolidating into one piece of equipment, part out the Hinomoto and sell the 400LD.
Based on the specifications of the 400LD (Lift Capacity, fully Raised 1450 lbs.) I thought an L4400/L4600 with appropriate loader would work. Before I get flamed, I fully realize machine weight, stability, ballast, etc. all are very important considerations. My current loader is only 50" wide, although it weights 5075 lbs. plus I carry a 400 lbs. ballast on rear when handling round bales. It would be suicide to run that loader out into a field with a round bale in the air...I get it. Again, all my offloading/storage/rebaling is done on a solid level pad.
Regardless, Kubota dealer #1 and #2 just laughed and said a MX5100 was where you start...dealer #3 said a M5640SUD was a minimum. I am not trying to figure that out at this time...they all make good arguments about having increased wheelbase, machine weight, loader capacity...all backed by the apparent marginal cost difference (I was looking at 4WD, HST plus some options...so these other recommendations were only $3 to $5K higher).
However, I have an investment in 5' equipment (shredder, box blade, aerator, etc., space in my garage for a smaller tractor (any new one is going to be stored inside), some pasture fencing limitations where a 6'+ width will not fit, etc. Just looking at these other machines they seem overkill for what I do on a regular basis (again, I have been using a sub-compact for decades).
Therefore looking for opinions on whether the L4400/L4600 can handle the round bale portion of my needs. I planned on removing bucket and using skid type bale spear. I know either model would easily handle everything else I do.
Sorry for the diatribe. Any advise appreciated.
