Rotary Cutter Can kubota BX 25D handle a 48" brush hog?
   / Can kubota BX 25D handle a 48" brush hog? #1
Nellie08
Deming
Kubota BX 25D
I just purchased a Kubota BX 25D last year and the dealer sold me a 48" Land Pride brush hog. My question is, is this too big an implement for the machine or is it common? Will running it on about 1 1/2 acres about twice a year put too much stress on the transmission etc..
I know they sell a 42", maybe I should look into that.
Thank you.
   / Can kubota BX 25D handle a 48" brush hog? #2
You could use a 5 footer with no problem. The dealer would never steer you wrong.
Thanks for the input.
My profile was wrong. It is a BX 25D. Just wanted to make sure running such a large brush hog over time would not over work the unit. I know slowing down and making half passes would help.
   / Can kubota BX 25D handle a 48" brush hog? #4
My 2360 cuts with a 48 easily, but doesn't like carrying it raised. Some weight in the FEL would help.
I wouldn't want to carry a 5ft on my rough ground.
Bruce
   / Can kubota BX 25D handle a 48" brush hog? #5
That is about the perfect size for that machine.
   / Can kubota BX 25D handle a 48" brush hog? #6
Yeah, I just used mine on my BX25 (not D) twice this week. Mine came from Everything Attachments. My only complaint is that I can't figure out how to get my HF quick hitch working with it, so it's a PITA to get on and off. I've replaced the shear pin a couple times, but that seems to go with the territory. I'd DEFINITELY keep the FEL on for counterweight, but if you are like me, my FEL never comes off.
I think the 5 footer might be a little much in terms of comfortable weight and maneuvering though.
Thanks again.
Sounds like a consensus that the land Pride 48" brush hog is suitable for my machine.
BTW for anyone wondering about the quality and power to size ration of the BX 25D, don't be. It is an amazing unit perfectly suited for most jobs up to about 5-6 acres.
See ya'
   / Can kubota BX 25D handle a 48" brush hog? #8
I run a 48" LP on my BX2200 as well as BX2660, no problem.
Quick Attach Pallet Forks (A47384)
Quick Attach...
2007 JLG SkyTrak 10054 10,000LB 4x4 Rough Terrain Telehandler (A50322)
2007 JLG SkyTrak...
John Deere Ztrak M665 60in Zero Turn Mower (A48082)
John Deere Ztrak...
2016 Ford F-150 Ext. Cab Pickup Truck (A50323)
2016 Ford F-150...
2007 JOHN DEERE 624J WHEEL LOADER (A51406)
2007 JOHN DEERE...
20' Sea Container (A50774)
20' Sea Container...
