Rotary Cutter Can I?
   / Can I? #1
Stancoll
Bronze Member
Eastman, Georgia
Mahindra 2017 1526 Shuttle
On our hunting property we have found a wet weather hole (mini-eden) that we want easy access to. Its about 25-30 ft from a hunt plot but a lot of scrub stuff. About the thickest most of it is about the thickness of the little finger and about 3-4 ft tall. Pretty thick, just walking through is labor intensive. I tried going thru with my Mahindra 1526, but I'm nervous about tearing something at the undercarriage area. Would it hurt to back the rotary mower thru first backing in low 1st and the first cut real high? No stumps that we can see just scrub whatever it is. Your thought?
   / Can I? #2
I don't think it would hurt to back in it, be careful not to get stuck and also watch out for puncturing a tire after cutting it.
   / Can I?
Thanks, good thing to watch out for, punctured tire.
   / Can I? #4
yeah if it was me, I'd back in with the cutter raises as far as you can/want to go and start it cutting on the way back OUT. Do you have a loader? can you not set it on the ground and push the scrub stuff out?
   / Can I?
I do have the loader, I'll give it a try but I think with the slick tip it may ride under the bucket. Wish I had that Piranha Blade.looks like it might just grab the stuff while pushing. The scrub is grow over from old logging trail probaly 10 to 15 years ago.
   / Can I? #6
Trying to work through it with mower will probably end with a new tire or two and maybe branches stuck or poking holes on the tractor underside.
The toothed cutting bar and making a cleaned strip might be easier??
   / Can I? #7
(IMHO)
Like other say, if you back in have cutter raised high, then lower it onto what your cutting. Backing up about a cutter length at a time. It's hard to see what you backing into with heavy bush, and if you find that odd stump, rock, fence post, sapling that doesn't bend , etc... rotary mowers make one h*ll of a noise when the object pushes the mowers sheet metal lip into the blades as you back into it. Ask me how I know. :mad: -then comes the job of parking mower between 2 trees with 2 come-alongs, trying to bend the lip out again.
Other way is to go forward (slowly) and curl bucket down about 6-10" off the ground so that brush get snapped over or uprooted before they get mowed. This is also good method to find those hidden stumps, rocks, posts, etc... Not a fool proof system though, it might knock over 99%, but there will still be that ONE that will try to wedge itself in the wrong place. Go slow and watch.
   / Can I? #8
Depends on how much time you want to kill, and if you want to be looking backward over your shoulder all day.
If you only have a 25-30ft passage to clear... and don't feel comfortable on a tractor.... you could buy a good carbide tooth brush blade for your string trimmer for around $15 on eBay. Shouldn't take you any more than a couple hours to clear that short distance.
   / Can I? #9
Nothing over finger size?
I wouldn't think twice about it.
Back in with the cutter at what you normally cut at & get it done.
   / Can I? #10
Do it all the time. I set the loader about 6 inches off the ground and go slow and careful. You should be fine.
2017 NISSAN NV200 VAN (A51406)
2017 NISSAN NV200...
2017 Chevrolet Silverado 1500 Crew Cab Pickup Truck (A50323)
2017 Chevrolet...
INGERSOLL RAND 100KW GENERATOR (A50854)
INGERSOLL RAND...
2015 KENWORTH T800 MID-ROOF SLEEPER (A50854)
2015 KENWORTH T800...
2007 Pace American JT716TA2 20ft T/A Enclosed Trailer (A49461)
2007 Pace American...
1977 Allis Chalmers 7060 Tractor (A50514)
1977 Allis...
