Can I use mild hot-rolled 1" bar for bucket forks?
   / Can I use mild hot-rolled 1" bar for bucket forks? #1
TractorDale
fairfield, ct
TC 29DA
Can I use mild hot-rolled 1\" bar for bucket forks?
Or I wonder if the metal used by Payne's or whatever for forks is a cold rolled or a higher carbon steel? Thinking 1" x 5" and a hybrid upper and lower lip attachment design to allow easy lateral adjustment without loosening anything.
Thanks for your thoughts.
Dale
   / Can I use mild hot-rolled 1" bar for bucket forks? #2
Re: Can I use mild hot-rolled 1\" bar for bucket forks?
</font><font color="blue" class="small">( Or I wonder if the metal used by Payne's or whatever for forks is a cold rolled or a higher carbon steel? Thinking 1" x 5" and a hybrid upper and lower lip attachment design to allow easy lateral adjustment without loosening anything.
Dale )</font>
No idea what Paynes are made of...but I looked at a set that was 2 x 4 x 1/4" box material....sliced at an angle on the end and a plate welded over the end...so you didnt drive dirt..etc..down the "tube". Whatever material 2 x 4 box member is made of??
   / Can I use mild hot-rolled 1" bar for bucket forks? #3
I made mine of 1 1/2" x 4" C-Channel from the local scrap yard. Of course my bucket is only rated for 1050# lift cap. to full height at pivot points and 2172# breakaway cap. The C-Channel will handle more weight than the loader will lift.
   / Can I use mild hot-rolled 1" bar for bucket forks? #4
I believe that Payne's uses 3" x 4.10 bar channel which is mild CRS.
Have you seen my free plans on how to build these? Over 300 other TBN'ers have. If search is back working you can do a search here for bucket forks and you might find the post where my design is described. Or you can just PM me with your real email address and get a free set for yourself.
Better yet, I found it right here:
MadReferee's bucket forks
Nice looking forks-may use your plans.
thanks.
Dale
(8) 2 PLUG VALVES (A52472)
(8) 2 PLUG VALVES...
Tandem Axle Rear Truck Frame (A51692)
Tandem Axle Rear...
2004 Ford Taurus SE Sedan (A51694)
2004 Ford Taurus...
2018 John Deere 6215R MFWD Tractor (A53342)
2018 John Deere...
2007  BIG TEX 16' T/A TRASH TRAILER (A52472)
2007 BIG TEX 16'...
Hydraulic Hose Reel (A52377)
Hydraulic Hose...
