Backhoe can I use jimna backhoe with koyker loader & frame
   / can I use jimna backhoe with koyker loader & frame #1
Scratchnbell
Fish Camp,California
New Holland 2001 TC40d
Can I add the jimna backhoe to my 284 with the koyker 160 loader?
Bob
   / can I use jimna backhoe with koyker loader & frame #2
Yes you can Bob, but you have to weld some brackets on the rear front end loader mounts to hold the front of the backhoe frame. we use some pieces of 1/2" plate with a hole in it for the pins.Or you could use a Jinma 3-point backhoe also
Tommy
Affordable Tractor Sales
   / can I use jimna backhoe with koyker loader & frame #3
</font><font color="blue" class="small">( Can I add the jimna backhoe to my 284 with the koyker 160 loader?
Bob )</font>
Yes Bob you certainly can. Yancheng ships a set of centre
pylon mounts with "ears" as an option with the ZL-20 loaders
to attach the Hoe frame to the loader mounts. We order them
ala carte with the Hoes. We then cut the top plates off with a
Sawzall or plasma cutter and weld the "ears" to the cross
plates on the KOYKER centre pylon mounts. Perfect fit. We
also have a block of 1" steel plate machined to tie the Hoe
frame into the draw bar box for added strength.
Regards
Graham at Bolton Power
   / can I use jimna backhoe with koyker loader & frame #4
Graham or Tommy any chance you might have a picture that you could post, so we can see of what this set-up looks? ... Scozz
I'd also like a picture if possible.
The homier show is in town this weekend and I may see what I can pick up a back hoe for.
Is there any disadvantages to going with a three point hoe instead of a fixed one?
Bob
JOHN DEERE 1705/6700 LOT NUMBER 208 (A53084)
JOHN DEERE...
INVERTER TIG 350A WELDER (A51248)
INVERTER TIG 350A...
FAE 150/540 LOT NUMBER 72 (A53084)
FAE 150/540 LOT...
UNUSED FUTURE 20' BI-PARTING WROUGHT IRON GATE (A51248)
UNUSED FUTURE 20'...
PAIR OF VACUUM PUMPS (A53843)
PAIR OF VACUUM...
UNUSED GOLD MOUNTAIN M122009 12'X20' STEEL CARPORT (A51248)
UNUSED GOLD...
