Backhoe Can I swap buckets with a Cub Cadet Backhoe?
   / Can I swap buckets with a Cub Cadet Backhoe? #1
rockyridgefarm
Elite Member
NEOklahoma
Yanmar YT347
I have a JD 47 backhoe with a 9" bucket
My friend just got a used Kub L2900 with a Cub Cadet hoe and 13" bucket...
Anybody know if we can share buckets?
   / Can I swap buckets with a Cub Cadet Backhoe? #2
check the distance between the mounting plates, and the hole to hole distance,also see if pins are same size. if everything measures out try a swap. i have a kubota hoe and use a bucket i picked up at a farm sale, knew the measurements and used a tape measure at the sale to confirm. good luck
Anybod have any idea who builds the Cub Hoe?
   / Can I swap buckets with a Cub Cadet Backhoe? #4
I've got a Cub hoe.
I'm pretty certain it's a Woods.
GrayBeard
   / Can I swap buckets with a Cub Cadet Backhoe? #5
That makes a lot of sense because Woods made the FEL for Cub also.
2016 Autocar Xpeditor Garbage Truck (A51692)
2016 Autocar...
2009 IC Corporation PB105 Passenger Bus (A51692)
2009 IC...
Wolverine BC-13-72W, 72" Skid Steer Brush Cutter (A52384)
Wolverine...
2022 Ford Maverick Crew Cab AWD Pickup Truck (A50323)
2022 Ford Maverick...
2012 Toyota Camry Sedan (A50324)
2012 Toyota Camry...
Ford 1710 Tractor (AS IS) (A50774)
Ford 1710 Tractor...
