Can I put bigger rear/front tires on?
   / Can I put bigger rear/front tires on? #1
TractorMan187
Craftsman ys4500
Hello,
My current tractor (ys4500) has 20x8x8 tires on it. I was wondering if it would be possible to put bigger tires on, like maybe going from a 20" diameter to a 22" diameter, and maybe an 8" width to a 10" width. Would this be possible? Same with the fron. Enlarge by about 2 inches.
   / Can I put bigger rear/front tires on? #2
Easley done with a 2 wheel drive tractor. A 4 wheel drive tractor MUST have the front and rear tires of the correct diameter or you risk blowing the front wheel drive and that = $$$$$.
   / Can I put bigger rear/front tires on? #3
The circumference of the new tires MUST increase proportionally back:front if you have MFWD.
-Jer.
I don't have 4wd on my tractor, so thats not a problem.
Thanks for the info. Would I have to get new rims also?
I'm wondering because I wanted bigger brute tires for moving snow. Would it be better to just get chains for front/rear tires and wheel weights?
Thanks!
49" X 79" EXPANDED METAL RAMP GATE (A51247)
49" X 79" EXPANDED...
New Wolverine 3pt Receiver Hitch (A53002)
New Wolverine 3pt...
1994 Fiat Allis 65-B Motor Grader (A52384)
1994 Fiat Allis...
UNUSED KIVEL 3500# PALLET FORKS (A51248)
UNUSED KIVEL 3500#...
2016 John Deere 35G Mini Excavator (A52377)
2016 John Deere...
JOHN DEERE LOT NUMBER 167 (A53084)
JOHN DEERE LOT...
